Is there any way too Tell if a UIBuilder node has connections
Is there any way too Tell if a UIBuilder node has connections, would like to be able to check in a function or switch?
Utilising a status node set to the uibuilder node to keep track of the number of connections? Otherwise send an outgoing message on connect/disconnect events from the uibuilderfe code and connect your flow to that
The 2nd output gives out control messages whenever a client connects or disconnects. Of course, a "client" could be a new device or a new browser/tab/window on the same device.
And, as Lena says, the uibuilder node outputs a status with the number of connected clients and so you can take the status text and process it.
Thank You that was what I wanted
