Issue with microphone
Hi
I tested the flow individually it was working but when i connect to mic it has this problem.
It would be helpful if you tell us
  1. version of NR and Node.js (see startup log)?
  2. the platform you are using, os and version?
  3. what microphone node are you using?
  4. what speech to text node are you using?
  5. how long did you speak into the mic?
Plus a copy of your flow (make sure to use three backtic's before and after the flow.
