Issue with "node-red-contrib-gree-hvac"
Hello all,
I am trying to play with "node-red-contrib-gree-hvac". I am able to install the palette and configure one device. Once deployed I can see in debut information from the AC unit:
Once I start to do anything else I have got this error message and NR is gong into restart.
7 Feb 22:18:55 - [red] Uncaught Exception:
7 Feb 22:18:55 - [error] TypeError: Cannot read properties of undefined (reading '0')
at /home/openhabian/.node-red/node_modules/gree-hvac-client/lib/client.js:383:46
at Array.forEach ()
at Client._handleUpdateConfirmResponse (/home/openhabian/.node-red/node_modules/gree-hvac-client/lib/client.js:382:18)
at Client._handleResponse (/home/openhabian/.node-red/node_modules/gree-hvac-client/lib/client.js:312:29)
at Socket. (/home/openhabian/.node-red/node_modules/gree-hvac-client/lib/client.js:113:52)
at Socket.emit (node:events:513:28)
at UDP.onMessage [as onmessage] (node:dgram:930:8)
nodered.service: Main process exited, code=exited, status=1/FAILURE
nodered.service: Failed with result 'exit-code'.
nodered.service: Consumed 8.968s CPU time.
nodered.service: Scheduled restart job, restart counter is at 4.
Stopped Node-RED graphical event wiring tool.
Any idea what could be wrong?
Jan K.
You may want to look here.
Thanks, seems to be working. I have the same change to client.js file and all my four units are working, accepting commands from NR.
