I have a question about the use of the dashboard template node.
I have a template that contains some code to set a switch, (I can not use the dashboard switch node for this because of some custom stuff)
here is the code that is in the template:
<div layout="row" layout-align="space-between center">
<p>test switch</p>
<md-switch aria-label="test" ></md-switch>
</div>
When I set the size of the node to auto, it looks like this (used two template nodes here with the exact same code for clearity):
Which is a bit on the high side
However, when I set the size of the node to 6x1 it looks like this:
Got two bonus scroll bars on the right side.
This seems to be caused by the overflow-y: auto setting of the nr-dashboard-template CSS class. Removing that setting (using Chrome's developer mode) turns it into this:
Which is fine.
So, to cut a long story short.. how can I roll my own app.min.css to fix this, or is there another way ?
(running latest version of Node-red on Armbian 5.38)
