Java Script Object to Json array
Can we parse two value separated by '#'
The ideal tool to use for this is the JSONata expression language, as @afelix mentioned above...
For your example payload, you can use a change node with the following J: expression right in the tester, and see the results in real-time as you are typing the expression:
