Join into an array... How to pass into the same place every time
I'm moving values from the JSON nodes into an array but they seem to come through in an uncertain order. Is there a way to make sure the same node moves its value into the same place in the array every time?
        "id": "cd97b652011b3194",
        "type": "json",
        "z": "f818e70d04de7231",
        "property": "payload",
        "action": "",
        "pretty": false,
        "x": 870,
        "y": 760,
                "77f71195666e5cde"
        "id": "8ca5f8b66f1a49b6",
        "type": "http in",
        "url": "a",
        "method": "get",
        "upload": false,
        "swaggerDoc": "",
        "x": 170,
        "y": 780,
                "59cbc5672c44b899",
                "6cfd30233baac18c",
                "b3daa3897de2cd84",
                "6ae4c2b4eca2b6a3",
                "4ebccf086882b47a",
                "4e39cef70cad66a0",
                "743ee07924c09fb5",
                "938f781def71e5da"
        "id": "e4b08ea88cbc34a2",
        "type": "http response",
        "statusCode": "200",
        "headers": {
            "content-type": "text/html"
        "x": 1560,
        "y": 920,
        "id": "d8ded07f12cffaa0",
        "type": "json",
        "action": "",
        "pretty": false,
        "x": 870,
        "y": 820,
                "77f71195666e5cde"
        "id": "3b00fddcc2006cd2",
        "type": "json",
        "action": "",
        "pretty": false,
        "x": 870,
        "y": 880,
                "77f71195666e5cde"
        "id": "77f71195666e5cde",
        "type": "join",
        "mode": "custom",
        "build": "array",
        "propertyType": "msg",
        "key": "topic",
        "joiner": "\\n",
        "joinerType": "str",
        "accumulate": false,
        "timeout": "",
        "count": "8",
        "reduceRight": false,
        "reduceExp": "",
        "reduceInit": "",
        "reduceInitType": "",
        "reduceFixup": "",
        "x": 1090,
        "y": 920,
                "3e971cfe0f70f389",
                "f3aa309b5130a48c"
        "id": "f3aa309b5130a48c",
        "type": "function",
        "name": "function 2",
        "func": "// Retrieve the values from the array\nconst [value1, value2, value3] = msg.payload;\n\n// Round the values to 2 decimal places\nconst Value1 = Number(value1).toFixed(0);\nconst Value2 = Number(value2).toFixed(0);\nconst Value3 = Number(value3).toFixed(0);\n\n// Set the rounded values to be used in the template node\nmsg.payload = {\n    \"value1\": Value1,\n    \"value2\": Value2,\n    \"value3\": Value3\n};\n\nreturn msg;\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1240,
        "y": 920,
                "5ee6bb4a19739f1a"
        "id": "5ee6bb4a19739f1a",
        "type": "template",
        "field": "payload",
        "fieldType": "msg",
        "format": "handlebars",
        "syntax": "mustache",
        "template": "<!DOCTYPE html>\n<html>\n\n<head>\n  <title>Displaying 10 really big</title>\n  <style>\n    /* Import the Montserrat font from Google Fonts */\n    @import url('https://fonts.googleapis.com/css2?family=Montserrat:wght@400;700&display=swap');\n\n    .big-number {\n      font-family: 'Montserrat', sans-serif;\n      /* Set the font to Montserrat */\n      font-size: 10rem;\n      font-weight: bold;\n      text-align: center;\n      margin-top: 100px;\n      color: #27ae60;\n      text-shadow: 2px 2px 4px rgba(0, 0, 0, 0.3);\n    }\n\n    .assembly-line {\n      font-family: 'Montserrat', sans-serif;\n      /* Set the font to Montserrat */\n      font-size: 1.5rem;\n      /* Set the font size to be smaller */\n      font-weight: bold;\n      text-align: center;\n      color: black;\n    }\n\t\n\t\n\t.boxbottomtext {\n      font-family: 'Montserrat', sans-serif;\n      /* Set the font to Montserrat */\n      font-size: 1.5rem;\n      /* Set the font size to be smaller */\n      font-weight: bold;\n      text-align: center;\n      color: white;\n    }\n\t\n\t\n  </style>\n</head>\n\n<body>\n  \n\n  <div id=\"myChart\"></div> <!-- Add an element with the ID 'myChart' -->\n\n  <script language=\"javascript\">\n    setTimeout(function(){\n       window.location.reload(1);\n    }, 2000);\n  </script>\n\n  <script src=\"https://d3js.org/d3.v6.min.js\"></script>\n\n  <script>\n   var svg = d3.select(\"#myChart\")\n            .append(\"svg\")\n            .attr(\"width\", 400)\n            .attr(\"height\", 400)\n            .attr(\"id\", \"mySvg\"); // Add an ID to the SVG element\n/*\n    var circleColor = \"{{payload.value3}}\" === \"true\" ? \"green\" : \"red\"; // Set the color based on the value of payload.value3\n\n    svg.append(\"circle\")\n       .attr(\"cx\", 200)\n       .attr(\"cy\", 200)\n       .attr(\"r\", 100)\n       .attr(\"fill\", circleColor); // Use the color variable to set the fill color\n\t   \n\t   \n\t   var svg = d3.select(\"#myChart\")\n    .append(\"svg\")\n    .attr(\"width\", 400)\n    .attr(\"height\", 400);\n\t\n\t*/\t\n\nvar rect = svg.append(\"rect\")\n    .attr(\"x\", 150)\n    .attr(\"y\", 150)\n    .attr(\"width\", 400)\n    .attr(\"height\", 100)\n    .attr(\"fill\", function() {\n        if ({{payload.value3}} == true) {\n            return \"green\";\n        } else {\n            return \"red\";\n        }\n    });\n\t\nvar text = svg.append(\"text\")\n        .classed(\"boxbottomtext\", true)\n        .attr(\"x\", 200)\n        .attr(\"y\", 200)\n        .attr(\"text-anchor\", \"middle\")\n        .attr(\"dominant-baseline\", \"middle\")\n        .text({{payload.value3}} ? \"RUNNING\" : \"STOPPED\");\n\n\n  </script>\n  \n  \n<div class=\"big-number\" id=\"big-number\">{{payload.value1}}</div>\n  <div class=\"big-number\" id=\"big-number\">{{payload.value2}}</div>\n  <div class=\"big-number\" id=\"big-number\">{{payload.value3}}</div>\n  <div class=\"assembly-line\">ASSEMBLY LINE E</div>\n</body>\n\n</html>\n\n\n\n\n",
        "output": "str",
        "x": 1400,
        "y": 920,
                "e4b08ea88cbc34a2"
        "id": "59cbc5672c44b899",
        "type": "OpcUa-Item",
        "item": "ns=2;s=BAR-LIN-LINEH.PLC.CycleCount",
        "datatype": "Int32",
        "value": "",
        "name": "Line H Count",
        "x": 370,
        "y": 700,
                "27c3b28115eae0a1"
        "id": "27c3b28115eae0a1",
        "type": "OpcUa-Client",
        "endpoint": "7290d8b0.f713d8",
        "action": "read",
        "deadbandvalue": "",
        "time": "5",
        "timeUnit": "s",
        "localfile": "",
        "localkeyfile": "",
        "folderName4PKI": "",
        "name": "Test server (subscribe items)",
        "x": 620,
        "y": 700,
                "5879ef033770e553"
        "id": "6cfd30233baac18c",
        "item": "ns=2;s=BAR-LIN-LINEG.PLC.CycleCount",
        "value": "",
        "name": "Line G Count",
        "x": 370,
        "y": 760,
                "2b2f1a74949e8a15"
        "id": "2b2f1a74949e8a15",
        "action": "read",
        "time": "5",
        "timeUnit": "s",
        "localfile": "",
        "localkeyfile": "",
        "x": 620,
        "y": 760,
                "cd97b652011b3194"
        "id": "b3daa3897de2cd84",
        "item": "ns=2;s=BAR-LIN-LINEF.PLC.CycleCount",
        "value": "",
        "name": "Line F Count",
        "x": 370,
        "y": 820,
                "996a93e370e41fbc"
        "id": "996a93e370e41fbc",
        "action": "read",
        "time": "5",
        "timeUnit": "s",
        "localfile": "",
        "localkeyfile": "",
        "x": 620,
        "y": 820,
                "d8ded07f12cffaa0"
        "id": "5879ef033770e553",
        "type": "json",
        "action": "",
        "pretty": false,
        "x": 870,
        "y": 700,
                "77f71195666e5cde"
        "id": "4ebccf086882b47a",
        "item": "ns=2;s=BAR-LIN-LINEE.PLC.CycleCount",
        "value": "",
        "name": "Line E Count",
        "x": 370,
        "y": 880,
                "1fa7137ce2f0ef47"
        "id": "1fa7137ce2f0ef47",
        "action": "read",
        "time": "5",
        "timeUnit": "s",
        "localfile": "",
        "localkeyfile": "",
        "x": 620,
        "y": 880,
                "3b00fddcc2006cd2"
        "id": "6ae4c2b4eca2b6a3",
        "item": "ns=2;s=BAR-LIN-LINEE.PLC.Status",
        "datatype": "UInt16",
        "value": "",
        "name": "Line E Status",
        "x": 370,
        "y": 1160,
                "0de625764d428a74"
        "id": "0de625764d428a74",
        "action": "read",
        "time": "5",
        "timeUnit": "s",
        "localfile": "",
        "localkeyfile": "",
        "x": 620,
        "y": 1160,
                "cfb68065e3ab5ad1"
        "id": "938f781def71e5da",
        "item": "ns=2;s=BAR-LIN-LINEF.PLC.Status",
        "value": "",
        "name": "Line F Status",
        "x": 370,
        "y": 1100,
                "5b29f5bad43f35cf"
        "id": "5b29f5bad43f35cf",
        "action": "read",
        "time": "5",
        "timeUnit": "s",
        "localfile": "",
        "localkeyfile": "",
        "x": 620,
        "y": 1100,
                "40921b4eb67536fe"
        "id": "743ee07924c09fb5",
        "item": "ns=2;s=BAR-LIN-LINEG.PLC.Status",
        "value": "",
        "name": "Line G Status",
        "x": 380,
        "y": 1040,
                "c5f2c82e45874619"
        "id": "c5f2c82e45874619",
        "action": "read",
        "time": "5",
        "timeUnit": "s",
        "localfile": "",
        "localkeyfile": "",
        "x": 620,
        "y": 1040,
                "d2cd44d5ed3d44b9"
        "id": "4e39cef70cad66a0",
        "item": "ns=2;s=BAR-LIN-LINEH.PLC.Status",
        "value": "",
        "name": "Line H Status",
        "x": 380,
        "y": 980,
                "d76090bef0a93e2b"
        "id": "d76090bef0a93e2b",
        "action": "read",
        "time": "5",
        "timeUnit": "s",
        "localfile": "",
        "localkeyfile": "",
        "x": 620,
        "y": 980,
                "9a0bb4577a31b3b4"
        "id": "d2cd44d5ed3d44b9",
        "type": "json",
        "action": "",
        "pretty": false,
        "x": 870,
        "y": 1040,
                "77f71195666e5cde"
        "id": "40921b4eb67536fe",
        "type": "json",
        "action": "",
        "pretty": false,
        "x": 870,
        "y": 1100,
                "77f71195666e5cde"
        "id": "cfb68065e3ab5ad1",
        "type": "json",
        "action": "",
        "pretty": false,
        "x": 870,
        "y": 1160,
                "77f71195666e5cde"
        "id": "9a0bb4577a31b3b4",
        "type": "json",
        "action": "",
        "pretty": false,
        "x": 870,
        "y": 980,
                "77f71195666e5cde"
        "id": "3e971cfe0f70f389",
        "type": "debug",
        "name": "debug 5",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 1200,
        "y": 660,
        "id": "7290d8b0.f713d8",
        "type": "OpcUa-Endpoint",
        "endpoint": "opc.tcp://10.50.66.175:49320",
        "none": false,
        "login": false,
        "usercert": false,
        "usercertificate": "",
        "userprivatekey": ""
Could you sort the array on a particular column of the array?
Join as key/value object, then you can use the object to create the array, guaranteeing the array order.
Example, the split values have a random delay, so can not guarantee the delivery order.
Joining them as object, then using template to guarantee the order.
[{"id":"a717f8645c06d878","type":"inject","z":"65617ffeb779f51c","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"one\":1,\"two\":2,\"three\":3}","payloadType":"json","x":470,"y":4560,"wires":[["c3b9bbf9f5ac4007"]]},{"id":"c3b9bbf9f5ac4007","type":"split","z":"65617ffeb779f51c","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"topic","x":670,"y":4560,"wires":[["4b592f2367138ff7"]]},{"id":"4b592f2367138ff7","type":"delay","z":"65617ffeb779f51c","name":"","pauseType":"random","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":800,"y":4560,"wires":[["900b6933ebe52568","b297b79cdbcc6f7c"]]},{"id":"900b6933ebe52568","type":"join","z":"65617ffeb779f51c","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"3","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":510,"y":4660,"wires":[["ac893f12ba0b88b1"]]},{"id":"b297b79cdbcc6f7c","type":"debug","z":"65617ffeb779f51c","name":"debug 250","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":830,"y":4660,"wires":[]},{"id":"ac893f12ba0b88b1","type":"template","z":"65617ffeb779f51c","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"[\n{{payload.one}},\n{{payload.two}},\n{{payload.three}}\n]","output":"json","x":660,"y":4660,"wires":[["b297b79cdbcc6f7c"]]}]
Thankyou so much. I love the example, shows it perfectly!
