Join/Merge msg.payload with text/string
Hi.
I'm trying to construct a flow which I'll check all end devices (with battery) to get their battery level and send me a notification weekly, for instance.
So I need to collect some states from entities, create only one "message/text" and send it as a notification.
I get the values (two of them on this example), but I just get the number (the main info) and it is correct, but I'd like to add the text (the name of each device, for instance) but I don't know how could I change it.
Could anyone help me, please?
Thanks.
[{"id":"d080e9c42da40370","type":"tab","label":"Battery - Status","disabled":false,"info":"","env":[]},{"id":"9679fb12eb0a6e6d","type":"debug","z":"d080e9c42da40370","name":"debug 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":540,"y":240,"wires":[]},{"id":"cd3d227d8ed2f4a0","type":"inject","z":"d080e9c42da40370","name":"Timer","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":90,"y":120,"wires":[["1493492c7d77d7ba","d0150ec0a139be5a"]]},{"id":"1493492c7d77d7ba","type":"api-current-state","z":"d080e9c42da40370","name":"Lock - Main","server":"fad61953.26ffa8","version":3,"outputs":2,"halt_if":"0","halt_if_type":"num","halt_if_compare":"gte","entity_id":"sensor.sala_fechadura_battery","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":270,"y":60,"wires":[["c0f7cde410f9c2eb"],[]]},{"id":"d0150ec0a139be5a","type":"api-current-state","z":"d080e9c42da40370","name":"Lock - Kitchen","server":"fad61953.26ffa8","version":3,"outputs":2,"halt_if":"0","halt_if_type":"num","halt_if_compare":"gte","entity_id":"sensor.cozinha_fechadura_battery","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":280,"y":120,"wires":[["c0f7cde410f9c2eb"],[]]},{"id":"f6a98c037a1bfe72","type":"join","z":"d080e9c42da40370","name":"","mode":"custom","build":"array","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"num","reduceFixup":"","x":590,"y":80,"wires":[["9679fb12eb0a6e6d"]]},{"id":"c0f7cde410f9c2eb","type":"batch","z":"d080e9c42da40370","name":"","mode":"count","count":"2","overlap":0,"interval":10,"allowEmptySequence":false,"topics":[],"x":450,"y":80,"wires":[["f6a98c037a1bfe72"]]},{"id":"fad61953.26ffa8","type":"server","name":"Home Assistant","version":4,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30,"areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m"}]
Hi have you looked at the template node.
e.g.
[{"id":"cd3d227d8ed2f4a0","type":"inject","z":"d080e9c42da40370","name":"Timer","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":90,"y":120,"wires":[["1493492c7d77d7ba","d0150ec0a139be5a"]]},{"id":"1493492c7d77d7ba","type":"api-current-state","z":"d080e9c42da40370","name":"Lock - Main","server":"fad61953.26ffa8","version":3,"outputs":2,"halt_if":"0","halt_if_type":"num","halt_if_compare":"gte","entity_id":"sensor.sala_fechadura_battery","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":270,"y":60,"wires":[["30ac16fd.1a9aea"],[]]},{"id":"d0150ec0a139be5a","type":"api-current-state","z":"d080e9c42da40370","name":"Lock - Kitchen","server":"fad61953.26ffa8","version":3,"outputs":2,"halt_if":"0","halt_if_type":"num","halt_if_compare":"gte","entity_id":"sensor.cozinha_fechadura_battery","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":280,"y":120,"wires":[["c8ae02e0.d49b2"],[]]},{"id":"30ac16fd.1a9aea","type":"change","z":"d080e9c42da40370","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"main","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":530,"y":60,"wires":[["f6a98c037a1bfe72"]]},{"id":"c8ae02e0.d49b2","type":"change","z":"d080e9c42da40370","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"kitchen","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":530,"y":120,"wires":[["f6a98c037a1bfe72"]]},{"id":"f6a98c037a1bfe72","type":"join","z":"d080e9c42da40370","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"num","reduceFixup":"","x":690,"y":80,"wires":[["8173e9ac.4ba678"]]},{"id":"8173e9ac.4ba678","type":"template","z":"d080e9c42da40370","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"this will join {{payload.main}} with {{payload.kitchen}}","output":"str","x":460,"y":200,"wires":[["9679fb12eb0a6e6d"]]},{"id":"9679fb12eb0a6e6d","type":"debug","z":"d080e9c42da40370","name":"debug 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":650,"y":180,"wires":[]}]
If you look in the Current state node that you are using you can retrive multiple bits of data - in your case you are retrieving the entity and putting that in msg.data
so you can access this property and do with it what you want
Craig
