Json Data Pushed from Inverter
@Bigben83 have you seen this post? Perhaps instead of the push service you could request data from its cgi endpoints?
Just a thought.
Yes, I had seen this, but it doesn't push the data that I'm after, it only sends power generation and consumption data.
OK, well in that case look at this...
https://repl.it/join/ozrhutci-stephenmclaughl
The code shows you how to take the first key out of an object.
So in your case, you could add a function node AFTER the HTTP IN node and add the following...
Option 1 - get the key & pass it out to a JSON node
var k = Object.keys(msg.payload)[0];//get first key in the payload object
msg.payload = k;
or
Option 2 - turn k into an object then pass it out (no JSON node needed)
msg.payload = JSON.parse(k)
Give it a go. Put debug nodes before & after (to see if its working)
EDIT.
Could you also paste the data you get from the inverter into your reply?
... i can then check it is valid JSON
ok this is what I got when I did the above. so that's briliant.
@Steve-Mcl Thanks heaps for your help. got the result that i needed.
Nice to see you got it working. A tip for the future to make things easier for yourself (and others reading along): if you give your debug nodes a name, the name is shown up in the debug sidebar as well, so rather than "node: efe050dc.1e1e5" it will show "node: my debug node" instead
