Jsonata chain operator giving different results
Given some JSON:
  "A": 1,
  "B" : 2,
  "C": 3
I'd expect this Jasonata statement $spread($)[*=2] to gives these results (which it does indeed):
   "B": 2
But when I use what I believe to be semantically the same statement but use the chain operator: $~>$spread()[*=2] it gives the results:
    "A": 1
    "B": 2
    "C": 3
Could anyone explain why Jsonata processes those two statements which in my estimation should yield identical results, but are handled so differently? Is there something I don't understand about the chain operator?
Thanks in advance!
The chain parts need to be in parentheses
e.g
($~>$spread())[*=2]
[edit] removed typo
Thank you! Great insight! Do you understand why? Is it an order of operations problem?
I believe the spread is applying the filter to each property of the object, rather than the finished array.
