JSONata - keys with dashes
I have some trouble selecting data from json, most key names contain dashes and jsonata does not seem to play along with it.
Example source (reality is much longer, many interfaces)
  "rpc-reply": {
      "xmlns:junos": "http://xml.juniper.net/junos/12.1X47/junos"
    "interface-information": [
          "xmlns": "http://xml.juniper.net/junos/12.1X47/junos-interface",
          "junos:style": "terse"
        "physical-interface": [
            "name": [
              "ge-0/0/0"
            "admin-status": [
              "up"
            "oper-status": [
              "up"
            "logical-interface": [
                "name": [
                  "ge-0/0/0.0"
                "admin-status": [
                  "up"
                "oper-status": [
                  "up"
                "filter-information": [
                  "\n                "
            "name": [
              "gr-0/0/0"
            "admin-status": [
              "up"
            "oper-status": [
              "up"
            "name": [
              "ip-0/0/0"
            "admin-status": [
              "up"
            "oper-status": [
              "up"
I want to select from physical-interface, its admin-status where the literal name is ge-0/0/0.
Trying JSONata:
*["physical-interface"] // result - all
*["physical-interface"].name // no result
*["physical-interface"][name='ge-0/0/0'] // no result
*["physical-interface"]['name'='ge-0/0/0'] // no result
*["physical-interface"][name='ge-0/0/0'].['admin-status'] // no result
**.name // 2 results
How does it work ? Does it work ? Or should i replace all keynames first ?
*["physical-interface"] Doesn't seem to be the correct syntax to select all interfaces, can you post an example with at leat 2 interfaces ?
hmm not sure what you mean, I have edited the post with more interfaces.
Ah, name is an array, this seems to works for me:
https://try.jsonata.org/0mypfEmj
Seems like keys with dashes need to be between backquotes:
**[name[0]="ge-0/0/0.0"].`admin-status`
Try **."physical-interface"[name[0]='ge-0/0/0']."admin-status"
this was tricky becase the name are all arrays - i.e. "name": ["ge-0/0/0"],
p.s. to test it, change the admin-status from 'up' to something else.
Yes that confused me, because jsonata is used to select/search in arrays, except when trying to get this part.
@nlecaude thanks, this works!
