JSONata ~> (transform) question
I'm trying to keep 'last_seen' values (milliseconds) about several devices in a global hash called 'last_seen' using MAC addresses as keys. e.g.:
    "11-22-33-44-55-66": {"last_seen": 0,"reported": false},
    "AABBCCDDEEFF": {"last_seen": 0,"reported": false}
Query works fine,
$lookup($globalContext('last_seen'),payload)
but how do I update values?
Tried a 'change' node with this
$globalContext('last_seen')~>|payload|{"last_seen": $millis()}|
but it doesn't work. What am I missing?
Must it be JSONata?
It is easily achieved in a function...
var mac_to_update = msg.payload;  //or where ever it comes from
if(!mac_to_update) return msg;  //nothing to update!
var last_seen = global.get('last_seen') || {};  //get or create the global object
if(!last_seen[mac_to_update]) last_seen[mac_to_update] = {};  //handle empty/new mac
last_seen[mac_to_update].last_seen = Date.now();  //set last_seen
global.set('last_seen',last_seen);  //store back in global
return msg;//return to next node
Thanks for your code!
I'd very much like it to be JSONata, yes - it's kinda made for this sort of thing. I'm just having a hard time wrapping my head around ~>
Here an example of how it can be done:
last_seen ~> | $lookup($,$$.new_value.MAC) | { "last_seen" : $millis(),
                                               "reported"  : $$.new_value.reported} |
So the input of this JSONata expression consists of:
  • new_value : specifying the MAC address that needs to be updated + new reported value.
  • last_seen : is the json string that must be updated.
The input I have used as example:
  "new_value": {
    "MAC": "AABBCCDDEEFF",
    "reported": true
  "last_seen": {
      "last_seen": 0,
      "reported": false
    "AABBCCDDEEFF": {
      "last_seen": 0,
      "reported": false
If this doesn't exactly do what you want then please share an example of the input and the expected output for that input.
Or it can be done with the $merge function
e.g.
[{"id":"2cd1fcf0.4fe704","type":"inject","z":"8d22ae29.7df6d","name":"","props":[{"p":"payload"},{"p":"last_seen","v":"","vt":"date"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"11-22-33-44-55-66","payloadType":"str","x":190,"y":2520,"wires":[["212634ed.7da8fc"]]},{"id":"212634ed.7da8fc","type":"change","z":"8d22ae29.7df6d","name":"","rules":[{"t":"set","p":"last_seen","pt":"global","to":"$merge([$globalContext(\"last_seen\"),{payload:{\"last_seen\":$millis(),\"reported\":true}}])","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":450,"y":2500,"wires":[["d6dae2d8.e5527"]]},{"id":"d6dae2d8.e5527","type":"debug","z":"8d22ae29.7df6d","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":650,"y":2500,"wires":[]}]
If you are having a hard time then whoever inherits the code (or yourself in a couple of years) will probably also have a hard time. That might be considered an argument for doing it in a more easy to understand way (such as a function node).
True, but I'm building an MVP, so whoever has to deal with it can just ask me :wink:
