A Change node JSONata question
I have two global variables:
global.mac = "E4:5F:01:FE:DC:BA"
and
global.macvendors = {
"E8:48:B8":"TP-Link",
"E4:5F:01":"Raspberry Pi",
"5C:CF:7F":"Espressif",
"D8:49:2F":"Canon"
So the vendor bit of mac is $substring($globalContext("mac"), 0, 8) or "E4:5F:01"
And the vendor is $globalContext("macvendors")."E4:5F:01" or "Raspberry Pi"
But I can't work out how to combine the two into a single command to get "Raspberry Pi"
$globalContext("macvendors").$substring($globalContext("mac"), 0, 8) is valid JSONata but confusingly it returns the mac address substring "E4:5F:01"
  1. How should I do this?
  2. Is macvendors structured properly or should it be an array?
Hi @jbudd
I believe this will work
  • Look up a value based on its key
I don't do much JSONata - so forgive me, if incorrect
$lookup($globalContext("macvendors"), $substring($globalContext("mac"), 0, 8))
Try this:
    $x := $substring($globalContext("mac"), 0, 8);
    $globalContext("macvendors").$x
Oops, mine returns the vendor mac not the name! Yours is, of course, much better. :slight_smile:
I use JSONata in my contributed node - I need to question my self if it doesn't work :grin:
I say 'use' - I allow it to be :sweat_smile:
Yes, many of mine now allow its use as well - though it is a pain to accommodate since it is async. I must admit that I've started using it a bit more since then as it is a great way to quickly add some dynamic processing to a field. Annoying though when you realise that you imagined seeing $sin and $tan functions in the list! :rofl:
Thanks both.
Yup, Marcus' $lookup works.
But why can I use
$globalContext("macvendors").string but not
$globalContext("macvendors").$function?
I think Julian's is a multi-line equivalent of my attempt.
I had attempted := (Pascal!) and ; but they were rejected.
Seems like the brackets round the whole lot are important.
I'm really not warming to JSONata's syntax :exploding_head:
I would agree - its a little odd.
its a love/hate relationship - I do like to use it in the right situation, but its a little odd in behaviour at times
I suspect it is due to the overloaded use of the dot separator. It is happy with a variable but not a function. I've been at this game far too long! :joy:
Yes the round brackets are critical.
It doesn't like variables either, that's why your expression returned the substring of the mac. The issue is the dot has two meanings, one the path notation, and two the mapping function. I think that is why they have lookup() rather than [ ].
Anyway here is an alternative way just for info.
$globalContext("macvendors." & $substring($globalContext("mac"), 0, 8))
Alternatively if the mac was in a msg property you could do it in the change node with no JSONata
set msg. payload
to global macvendors[msg.mac]
@E1cid's versions work too.
OK "macvenddors." & $substring($globalContext("mac"), 0, 8) is concatenation so this is
$globalContext("macvendors.E4:5F:01")
And indeed similar (javascript) syntax in a function node:
msg.payload = global.get("macvendors.E4:5F:01") works (who knew?)
"with no JSONata" wow, surprised to see that :laughing:
Thanks for the suggestions everyone, lots of food for thought there.
Three different solutions gathered together:
[{"id":"4519255c81d7c9d5","type":"inject","z":"52d3a9a7a5712824","name":"init","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":190,"y":1600,"wires":[["ec0e3ae6bef510f7"]]},{"id":"ec0e3ae6bef510f7","type":"change","z":"52d3a9a7a5712824","name":"set variables","rules":[{"t":"set","p":"mac","pt":"flow","to":"E4:5F:01:FE:DC:BA","tot":"str"},{"t":"set","p":"macvendors","pt":"flow","to":"{ \"E8:48:B8\":\"TP-Link\", \"E4:5F:01\":\"Raspberry Pi\", \"5C:CF:7F\":\"Espressif\", \"D8:49:2F\":\"Canon\" }","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":390,"y":1600,"wires":[[]]},{"id":"a7eb29e38e1d826d","type":"group","z":"52d3a9a7a5712824","name":"@marcus-j-davies  $lookup($flowContext(\"macvendors\"), $substring($flowContext(\"mac\"), 0, 8))","style":{"label":true},"nodes":["982b91a425b9e71b","31381589b1707f68","0a83a3ca160b355c"],"x":114,"y":1639,"w":612,"h":82},{"id":"982b91a425b9e71b","type":"change","z":"52d3a9a7a5712824","g":"a7eb29e38e1d826d","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$lookup($flowContext(\"macvendors\"), $substring($flowContext(\"mac\"), 0, 8))","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":400,"y":1680,"wires":[["0a83a3ca160b355c"]]},{"id":"31381589b1707f68","type":"inject","z":"52d3a9a7a5712824","g":"a7eb29e38e1d826d","name":"go","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"go","payloadType":"str","x":210,"y":1680,"wires":[["982b91a425b9e71b"]]},{"id":"0a83a3ca160b355c","type":"debug","z":"52d3a9a7a5712824","g":"a7eb29e38e1d826d","name":"debug 309","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":610,"y":1680,"wires":[]},{"id":"6e1dcc21fee97c56","type":"group","z":"52d3a9a7a5712824","name":"@ElCid #1: $flowContext(\"macvendors.\" & $substring($flowContext(\"mac\"), 0, 8))","style":{"label":true},"nodes":["773e66171b33cfc2","1de3b5add251d57b","d86fbc2e20c888af"],"x":114,"y":1739,"w":612,"h":82},{"id":"773e66171b33cfc2","type":"debug","z":"52d3a9a7a5712824","g":"6e1dcc21fee97c56","name":"debug 308","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":610,"y":1780,"wires":[]},{"id":"1de3b5add251d57b","type":"change","z":"52d3a9a7a5712824","g":"6e1dcc21fee97c56","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$flowContext(\"macvendors.\" & $substring($flowContext(\"mac\"), 0, 8))","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":400,"y":1780,"wires":[["773e66171b33cfc2"]]},{"id":"d86fbc2e20c888af","type":"inject","z":"52d3a9a7a5712824","g":"6e1dcc21fee97c56","name":"go","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"go","payloadType":"str","x":210,"y":1780,"wires":[["1de3b5add251d57b"]]},{"id":"b89f37ba67995e4c","type":"group","z":"52d3a9a7a5712824","name":"@ElCid #2  flow.macvendors[msg.myvendor]","style":{"label":true},"nodes":["7e01a416dcc22a61","8b448abe55d9b4cd","831fd2640cacf854"],"x":114,"y":1839,"w":612,"h":82},{"id":"7e01a416dcc22a61","type":"change","z":"52d3a9a7a5712824","g":"b89f37ba67995e4c","name":"","rules":[{"t":"set","p":"myvendor","pt":"msg","to":"$substring($flowContext(\"mac\"), 0, 8)","tot":"jsonata"},{"t":"set","p":"payload","pt":"msg","to":"macvendors[msg.myvendor]","tot":"global"}],"action":"","property":"","from":"","to":"","reg":false,"x":400,"y":1880,"wires":[["8b448abe55d9b4cd"]]},{"id":"8b448abe55d9b4cd","type":"debug","z":"52d3a9a7a5712824","g":"b89f37ba67995e4c","name":"debug 307","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":610,"y":1880,"wires":[]},{"id":"831fd2640cacf854","type":"inject","z":"52d3a9a7a5712824","g":"b89f37ba67995e4c","name":"go","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"go","payloadType":"str","x":210,"y":1880,"wires":[["7e01a416dcc22a61"]]}]
