@kevingodell/node-red-pipe2jpeg
The old unpublished node-red-contrib-pipe2jpeg has been re-built as @kevingodell/node-red-pipe2jpeg.
This node is similar to @BartButenaers' node-red-contrib-multipart-stream-encoder (node) - Node-RED, but serves a different purpose.
It is mostly a wrapper around the lib pipe2jpeg, which handles jpeg chunks that are piped from ffmpeg. An extra option to host image.jpeg and video.mjpeg http routes was added for convenience.
If you have used @kevingodell/node-red-mp4frag, you may notice some similarities.
You may only need this node if you are piping jpegs from ffmpeg. The reason is that the jpeg can be broken into buffer chunks to fit within your system's pipe if it is too big to fit as a single piece. It can arrive in 2 or more chunks and need to be re-assembled in some situations. Other times, there may be more than 1 jpeg packed into a single chunk. The internal dependency pipe2jpeg handles that buffer marker searching. To get further into the weeds, the start marker ff d8 and end markerff d9 may arrive at the beginning, middle, end of a chunk, or even have the ff arrive at the end of 1 chunk, with the d8 arrive in the next chunk.
You can set the option to output the buffer as an array of buffers or a single concatenated buffer. Array is preferred so that there is no extra memory allocation. The http routes can handle either setting with no problem. Buffer concatenation should be avoided to prevent an increase in memory usage, but you can do whatever you prefer.
If you are using @kevingodell/node-red-ui-mp4frag to view fragmented mp4 video from @kevingodell/node-red-mp4frag, then you can set the ready poster url to be the http path to /pipe2jpeg/<basePath>/image.jpeg and you will see the most recent jpeg right before the mp4 video loads.
As always, the documents are sparse. Import the example:
I would suggest that you do not directly send the jpegs to node-red-dashboard. The problem will be that even when you are not viewing a tab that is meant for showing the image, the jpeg will still be delivered and waste much bandwidth. Instead, send the playlist to the dashboard and have the front end widget request the jpegs on an interval.
[{"id":"0c43334e64655a4c","type":"ui_template","z":"0eb5dd623a753eb1","group":"a33e942d5385de1d","name":"jpeg reloader widget","order":14,"width":"6","height":"4","format":"<img ng-src=\"{{src}}\" ng-on-load=\"onLoad()\" class=\"jpeg-img\"/>\n\n<script>\n((scope) => {\n\n    scope.destroy = () => {\n\n        clearInterval(scope.reloader);\n\n        scope.src = ' '; // angular bug, give it some whitespace to clear img src\n\n    }\n\n    scope.$watch('msg', (msg) => {\n\n        scope.destroy();\n\n        if (msg && msg.payload && msg.payload.jpegImage) {\n\n            const { jpegImage } = msg.payload;\n\n            scope.src = jpegImage;\n\n            scope.reloader = setInterval(() => {\n\n                    scope.src = `${jpegImage}?t=${Date.now()}`;\n\n                },\n\n                2000\n\n            );\n\n        }\n\n    });\n\n    scope.$on('$destroy', scope.destroy);\n\n})(scope);\n</script>","storeOutMessages":true,"fwdInMessages":false,"resendOnRefresh":true,"templateScope":"local","className":"jpeg-widget","x":1680,"y":500,"wires":[[]]},{"id":"a33e942d5385de1d","type":"ui_group","name":"Group 1","tab":"8d2f4135ad04d074","order":1,"disp":true,"width":"6","collapse":false,"className":"jpeg-group"},{"id":"8d2f4135ad04d074","type":"ui_tab","name":"jpeg montage","icon":"dashboard","order":2,"disabled":false,"hidden":false}]
This node name followed the recommended scheme for naming nodes, the new node does not. You might consider renaming it to fit in with the accepted scheme.
Thank you for your feedback.
https://nodered.org/docs/creating-nodes/packaging
from the docs:
Naming
We updated our naming requirements on 31st January 2022. The following applies to modules first published after that date.
Packages should use a scoped name - such as @myScope/node-red-sample. That can be under a user scope or an organisation scope.
Nodes published under a scoped name have no further requirements on their name. They could use @myScope/node-red-sample or just @myScope/sample - although having node-red in the name does help to associate the module with the project.
If you are forking an existing package to provide a fix, you can keep the same name but released under your own scope. But please keep in mind, forking should always be a last resort if the original maintainer is not responsive to your contributions.
My apologies, I had missed the change!
