Layout issue with ui-edgewise-meter
Hoping I can get some guidance here with an alignment issue with the ui-edgewise-meter control. The problem I am having is that when I stack meters vertically they are all different sizes, it seems because the size of the meter depends on the length of the label.
I can't see how I can fix this in the dashboard layout. Is it fixable using CSS maybe, or is that just the way it is and I have to live with it?
Not looking for a full solution, just a pointer in the right direction.
Steve
You could leave the label blank in the meter and add text widgets of size 1x1 in front of each one, with just the label there.
Try
.hotnipi-ewm-label {
min-width: 5rem;
max-width: 5rem;
Maybe just width: will work too, didn't try it. And pixel sizes probably too, but percentages didn't work.
These are 3x1 widgets using 7rem.
That's not a bad workaround for simple cases (like this display on my phone) but of course forces you to fix the size of the group otherwise you can get a layout break between a label and its meter. If only there was support for nested groups so each label and meter could be bound together.
It's also not very granular - 1x1 + 2x1 - but I don't want to seem ungrateful.
Thanks for the suggestion
That looks promising - I'll have a play with that.
The basic implementation of all ui widgets should allow you to specify the layout and allocation of space between label and data.
Alas, it doesn't.
