Limit ui_text_input
Looked for examples but couldn't find any.
How can I limit the input of a ui_text_input numeric field to only positive numbers ?
If you use the 2 small up/down you can go from 0 to negative numbers.
Use a ui_numeric node instead?
use a ui_numeric field instead ?
Thanks, that's right. Of course when something is under my node I just can't see it :slight_smile:
