What node i can use it that input value(ex : 0~5000)?
Dear All :
Like title, How do to?
Thank u?
There are quite a few undeclared things you missed.
No problems.
But if you want to input them from a GUI (web page) you can use the text input node and set it to numbers.
That would/should work.
But you didn't say from where you wanted to input the value (or maybe better: HOW)
Dear Sir :
My english not well, Pardon me.
My mean is the input is like dialog,...
Thank u.
But you still didn't say HOW.... From a Web page or from an EDIT screen.
Maybe you need the inject node and set it to inject the desired value.
Dear Sir :
Can input value by PC keyboard?
Thank u?
Dear Sir :
May I use Text Input and select Number?
And which node can Restricted range?
Thank u.
I can't help you with that.
Just don't enter anything above 5000
If you are talking about the node-red-dashboard then the ui_numeric node can be set to limit the input
Sir :
I use textin, but I hope dont want hv the function int red circual! Just want input value use keyboard, But I dont know how to do?
Thank u.
If you are using a ui_text input - but set to numeric mode - then no - those arrows are added by your browser as a standard html5 feature - nothing to do with Node-RED. But you should still be able to type in the value if you wish (but you won't be limited).
Dear Sir :
Thank u very much.
  1. And how to disable in html5?
  2. ui_numeric has same function as red circual!
Thank u.
