Line pointing towards specific location. Worldmap GPSD
Hey!
I am currently building a gps tracker :
        "id": "edd053d57a890bfa",
        "type": "gpsd",
        "z": "1bfea58c27520ad5",
        "hostname": "localhost",
        "port": "2947",
        "tpv": true,
        "sky": true,
        "info": false,
        "device": false,
        "gst": false,
        "att": true,
        "x": 130,
        "y": 400,
                "2b73428fbe98e7cc",
                "909c0fc218f24b91",
                "afa924e8cd09b5d9",
                "256a2efdb683a1ba",
                "4470c68ef5843a91",
                "cc0512b5b772ea7d",
                "a06bc5439a0e432c",
                "6c52e3028e3485a2",
                "39b2902a54cf76f3"
        "id": "4470c68ef5843a91",
        "type": "function",
        "func": "msg.payload = {\n    name:\"\",\n    color: \"rgb(0,32,91)\",\n    icon : \"fa-crosshairs\",\n    iconColor : \"rgb(0,32,91)\",\n    iconSize : 500,\n    dasharray : \"30 20\",\n    lat : msg.payload.lat,\n    lon : msg.payload.lon,\n    \n}\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 400,
        "y": 400,
                "c0838482385fd77c",
                "136616a1efc48c37"
        "id": "c0838482385fd77c",
        "type": "worldmap-tracks",
        "depth": "5",
        "layer": "combined",
        "smooth": false,
        "x": 630,
        "y": 400,
                "136616a1efc48c37"
        "id": "136616a1efc48c37",
        "type": "ui_worldmap",
        "group": "0a1f43e2696f8d80",
        "order": 5,
        "width": 0,
        "height": 0,
        "lat": "",
        "lon": "",
        "zoom": "18",
        "layer": "OSMC",
        "cluster": "17",
        "maxage": "",
        "usermenu": "show",
        "layers": "hide",
        "panit": "true",
        "panlock": "false",
        "zoomlock": "false",
        "hiderightclick": "false",
        "coords": "deg",
        "showgrid": "true",
        "allowFileDrop": "false",
        "path": "/worldmap",
        "overlist": "DR,CO,RA,DN,HM",
        "maplist": "OSMG,OSMC,EsriC,EsriS,EsriT,EsriO,EsriDG,NatGeo,UKOS,OpTop,SW",
        "mapname": "",
        "mapurl": "",
        "mapopt": "",
        "mapwms": false,
        "x": 640,
        "y": 440,
        "id": "0a1f43e2696f8d80",
        "type": "ui_group",
        "name": "GNSS Tracker",
        "tab": "eb8313f9cc4c2238",
        "order": 1,
        "disp": false,
        "width": "20",
        "collapse": false,
        "className": ""
        "id": "eb8313f9cc4c2238",
        "type": "ui_tab",
        "icon": "fa-map-o",
        "order": 1,
        "disabled": false,
        "hidden": false
It is really simple so far. so if you have a look at it, it gets the location through gpsd and displays the driven path.
Now I was wandering if there is a possibility to display a line pointing towars a specific Lat- and Longitude even if your GNSS receiver is moving?
Thanks in advance!
normally we try to draw a leader line in the direction the device is heading based on the speed. However you can override this by setting your own msg.payload.bearing and msg.payload.length - so yes if you calculate the bearing to the lat lon required based on your current position you can draw whatever line you want.
