I've had a couple node red instances that I run in docker where the log.json file has grown to tens of GBs in only a few weeks/months. Are there environment variables in docker that can be used to limit log file size? Or other solutions? I've not investigated exactly what nodes are responsible but the flows I run are the same as in instances installed regularly and there I don't have this problem.
