Node-RED in Docker Logging
I recently had an issue where I needed to look at the log information for my flows during a restart. Having changed the logging level to trace, I found that my view of the console messages only showed so many lines. As a result, I was unable to see the entire refresh sequence of messages.
Is there a straightforward way to get the Node-RED logging into a file when it is running inside of the standard docker container?
For my other issue, what I did get was sufficient to find my issue, but had it been earlier in the sequence, I am not sure I would have had access to see it.
if you add a -f to the docker logs line it will stream it continuously and you can direct that to a file
docker logs -f [name of container]  > log.out
or if you look in /var/lib/docker/containers there will be a directory that starts with the same as the output of docker ps in there you should find a file that has the whole output of the container's stderr/stdout
Thanks for the pointer.
