Login failed on nodered
I installed Node-RED using Docker Compose, and I can access it via the IP address on port 1880. However, the issue is that I want authentication on the server. I created a hashed password and added it to settings.js, but it's not working as expected
 It looks like this;
adminAuth: {
type: "credentials",
users: [{
username: "admin",
password: "$2y$08$UiLPwUVDipQ7ktp0rwuncOwIfGAzeeQcDfuHWFOxbuoYKlB86D2S6",
permissions: "*"
but when i enter this credintials it says login failed. I dont know where is the problem.
Can someone help me? I dont know where the problem is?
Docker-compose.yml;
Version of NodeRED;
node-red --version
Node-RED v4.0.8
Node.js v20.18.2
Linux 5.15.0-126-generic x64 LE
Did you use the hashed credential to sign in or the string used to create the hashed credential. You should be using the string.
thanks it worked. i tried to enter same hash string to log in. i didnt know that i need to enter normal pasword which i gave for creating hash password.
Now you know the purpose of hashed passwords :smile:
