Logitech Harmony to MQTT Camera
Install Fakeroku on Node-RED
Open the Node-RED Menu in the top right corner and click on Manage Palette. There switch to the Install tab and search for fakeroku and install the node-red-contrib-fakeroku.
Now add a Fakeroku node to your flow and configure it as follows:
The IP address has to be set to the LAN IP of your Node-RED installation - in my case 192.168.2.111, you can keep the default port and multicast IP and click the + icon to generate a UUID for your device.
Now switch to your Harmony smartphone app and search for new devices on your network. Fakeroku will show up as a Roku 3. Continue by adding an Activity and save your settings.
Set up Node-RED to Update MQTT Topics
The Fakeroku virtual device will now give you access to the following buttons on your Harmony Remote:
For example Button 1 will send the payload string Rev to Node-RED when you press it.
In the following I want to connect it to a Node-RED flow that allows me to cycle through the first 4 preset positions of my Pan&Tilt camera using the INSTAR MQTT Service when this button is pressed.
Here is the complete list of actions that the complete flow will add:
  1. Rev - Go to last Preset Position
  2. Play - Start a x Second Video Recording
  3. Fwd - Go to next Preset Position
  4. Home - Deactivate the Alarm
  5. Up - Move Camera Up by one Step
  6. Right - Move Camera Right by one Step
  7. Down - Move Camera Down by one Step
  8. Left - Move Camera Left by one Step
  9. Select - Stop Camera Movement
  10. Back - Activate the Alarm
  11. Info - Trigger enabled Alarm Actions
The flow needed for those actions looks like this and can be downloaded and imported to Node-RED from the JSON export pasted in below:
Node-RED Flow
[{"id":"a7f685cf.720f58","type":"fakeroku-device","z":"1dfd915c.6102cf","confignode":"5699281e.1bbbc8","x":80,"y":180,"wires":[["f5aa6aa6.abeb78","3befcb89.667824","625b1ba9.24a254","62de79f2.f75328","1a8d0caa.b38743"]]},{"id":"f5aa6aa6.abeb78","type":"switch","z":"1dfd915c.6102cf","name":"PTZ","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Up","vt":"str"},{"t":"eq","v":"Down","vt":"str"},{"t":"eq","v":"Left","vt":"str"},{"t":"eq","v":"Right","vt":"str"},{"t":"eq","v":"Select","vt":"str"}],"checkall":"true","repair":false,"outputs":5,"x":286,"y":332,"wires":[["709a2dd0.a05e24"],["2b4c510.d949db"],["c4363ae8.54ee58"],["edf366d8.120318"],["ce60b71c.910af8"]]},{"id":"686b53b1.dee5fc","type":"mqtt out","z":"1dfd915c.6102cf","name":"features/ptz/movestep","topic":"instar/local/features/ptz/movestep/raw","qos":"1","retain":"","broker":"fbc900bc.b83bb","x":627,"y":332,"wires":[]},{"id":"709a2dd0.a05e24","type":"change","z":"1dfd915c.6102cf","name":"up","rules":[{"t":"set","p":"payload","pt":"msg","to":"up","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":415,"y":252,"wires":[["686b53b1.dee5fc"]]},{"id":"2b4c510.d949db","type":"change","z":"1dfd915c.6102cf","name":"down","rules":[{"t":"set","p":"payload","pt":"msg","to":"down","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":415,"y":292,"wires":[["686b53b1.dee5fc"]]},{"id":"c4363ae8.54ee58","type":"change","z":"1dfd915c.6102cf","name":"left","rules":[{"t":"set","p":"payload","pt":"msg","to":"left","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":415,"y":332,"wires":[["686b53b1.dee5fc"]]},{"id":"edf366d8.120318","type":"change","z":"1dfd915c.6102cf","name":"right","rules":[{"t":"set","p":"payload","pt":"msg","to":"right","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":415,"y":372,"wires":[["686b53b1.dee5fc"]]},{"id":"edd8e86c.1a00e8","type":"inject","z":"1dfd915c.6102cf","name":"Activate","topic":"","payload":"","payloadType":"num","repeat":"","crontab":"","once":true,"onceDelay":0.1,"x":605,"y":231,"wires":[["48e05d12.6b8d84"]]},{"id":"48e05d12.6b8d84","type":"change","z":"1dfd915c.6102cf","name":"Initialize","rules":[{"t":"set","p":"counter","pt":"flow","to":"-1","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":745,"y":231,"wires":[[]]},{"id":"ac59a9a4.a61318","type":"function","z":"1dfd915c.6102cf","name":"Counter","func":"var status = msg.payload;\n\nvar counter = flow.get(\"counter\") || 0;\n\nif (status == \"Fwd\")\n    {\n        \n        if (counter < 3)\n        {\n            counter = counter + 1;\n            flow.set(\"counter\",counter);\n            return msg;\n        }\n        else\n        {\n            counter = 0;\n            flow.set(\"counter\",counter);\n            return msg;\n            \n        }\n    }\n    \nelse {\n        \n    if (counter > 0)\n    {\n        counter = counter - 1;\n        flow.set(\"counter\",counter);\n        return msg;\n    }\n    else\n    {\n        counter = 3;\n        flow.set(\"counter\",counter);\n        return msg;\n    }\n}\n\n ","outputs":1,"noerr":0,"x":412,"y":182,"wires":[["e4ae5134.3976c"]]},{"id":"3befcb89.667824","type":"switch","z":"1dfd915c.6102cf","name":"FWD/REV","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Fwd","vt":"str"},{"t":"eq","v":"Rev","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":272,"y":180,"wires":[["ac59a9a4.a61318"],["ac59a9a4.a61318"]]},{"id":"7f883c84.232894","type":"mqtt out","z":"1dfd915c.6102cf","name":"features/ptz/preset","topic":"instar/local/features/ptz/preset/raw","qos":"1","retain":"","broker":"fbc900bc.b83bb","x":718,"y":182,"wires":[]},{"id":"e4ae5134.3976c","type":"function","z":"1dfd915c.6102cf","name":"Position","func":"msg.payload = flow.get(\"counter\") || 0;\n\nreturn msg;","outputs":1,"noerr":0,"x":550,"y":182,"wires":[["7f883c84.232894"]]},{"id":"625b1ba9.24a254","type":"switch","z":"1dfd915c.6102cf","name":"Home/Back","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Home","vt":"str"},{"t":"eq","v":"Back","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":277,"y":478,"wires":[["c3149921.424398"],["ecee0588.bb37f8"]]},{"id":"c3149921.424398","type":"change","z":"1dfd915c.6102cf","name":"1","rules":[{"t":"set","p":"payload","pt":"msg","to":"0","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":416,"y":460,"wires":[["d25c7f9e.b86d9","e28db00c.de5f7","32defe83.1910e2","5514217a.15a4","e5a74104.f5b2d"]]},{"id":"ecee0588.bb37f8","type":"change","z":"1dfd915c.6102cf","name":"0","rules":[{"t":"set","p":"payload","pt":"msg","to":"1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":416,"y":500,"wires":[["e5a74104.f5b2d","5514217a.15a4","32defe83.1910e2","e28db00c.de5f7","d25c7f9e.b86d9"]]},{"id":"e28db00c.de5f7","type":"mqtt out","z":"1dfd915c.6102cf","name":"alarm/area1/enable","topic":"instar/local/alarm/area1/enable/raw","qos":"","retain":"","broker":"fbc900bc.b83bb","x":632,"y":447,"wires":[]},{"id":"32defe83.1910e2","type":"mqtt out","z":"1dfd915c.6102cf","name":"alarm/area2/enable","topic":"instar/local/alarm/area2/enable/raw","qos":"","retain":"","broker":"fbc900bc.b83bb","x":632,"y":493,"wires":[]},{"id":"5514217a.15a4","type":"mqtt out","z":"1dfd915c.6102cf","name":"alarm/area3/enable","topic":"instar/local/alarm/area3/enable/raw","qos":"","retain":"","broker":"fbc900bc.b83bb","x":632,"y":539,"wires":[]},{"id":"e5a74104.f5b2d","type":"mqtt out","z":"1dfd915c.6102cf","name":"alarm/area4/enable","topic":"instar/local/alarm/area4/enable/raw","qos":"","retain":"","broker":"fbc900bc.b83bb","x":632,"y":585,"wires":[]},{"id":"d25c7f9e.b86d9","type":"mqtt out","z":"1dfd915c.6102cf","name":"features/ptz/preset","topic":"instar/local/features/ptz/preset/raw","qos":"1","retain":"","broker":"fbc900bc.b83bb","x":633,"y":400,"wires":[]},{"id":"62de79f2.f75328","type":"switch","z":"1dfd915c.6102cf","name":"Play","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Play","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":253,"y":644,"wires":[["bbdd25c2.7ca7e8","cc56f3e2.29cfb"]]},{"id":"782bc830.959dc8","type":"mqtt out","z":"1dfd915c.6102cf","name":"features/manualrec/start","topic":"instar/local/features/manualrec/start/raw","qos":"1","retain":"","broker":"fbc900bc.b83bb","x":612,"y":644,"wires":[]},{"id":"bbdd25c2.7ca7e8","type":"change","z":"1dfd915c.6102cf","name":"{\"val\":\"60\"}","rules":[{"t":"set","p":"payload","pt":"msg","to":"60","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":412,"y":644,"wires":[["782bc830.959dc8"]]},{"id":"cc56f3e2.29cfb","type":"delay","z":"1dfd915c.6102cf","name":"30s","pauseType":"delay","timeout":"30","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":248,"y":690,"wires":[["9a762fde.748ff"]]},{"id":"21d78cf6.3df984","type":"mqtt out","z":"1dfd915c.6102cf","name":"features/manualrec/stop","topic":"instar/local/features/manualrec/stop/raw","qos":"1","retain":"","broker":"fbc900bc.b83bb","x":612,"y":690,"wires":[]},{"id":"9a762fde.748ff","type":"change","z":"1dfd915c.6102cf","name":"{\"val\":\"off\"}","rules":[{"t":"set","p":"payload","pt":"msg","to":"off","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":408,"y":690,"wires":[["21d78cf6.3df984"]]},{"id":"ce60b71c.910af8","type":"change","z":"1dfd915c.6102cf","name":"right","rules":[{"t":"set","p":"payload","pt":"msg","to":"stop","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":415,"y":411,"wires":[["686b53b1.dee5fc"]]},{"id":"1a8d0caa.b38743","type":"switch","z":"1dfd915c.6102cf","name":"Info","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Info","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":231,"y":764,"wires":[["d6fd272a.1b92f8"]]},{"id":"94d84f16.62437","type":"mqtt out","z":"1dfd915c.6102cf","name":"alarm/pushalarm","topic":"instar/local/alarm/pushalarm/raw","qos":"1","retain":"","broker":"fbc900bc.b83bb","x":627,"y":764,"wires":[]},{"id":"d6fd272a.1b92f8","type":"change","z":"1dfd915c.6102cf","name":"1","rules":[{"t":"set","p":"payload","pt":"msg","to":"1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":379,"y":764,"wires":[["94d84f16.62437"]]},{"id":"5699281e.1bbbc8","type":"fakeroku-config","z":"","ip":"192.168.2.111","multicast":"239.255.255.250","uuid":"68580784e7ec5daf8d50f26874628384","port":"8086"},{"id":"fbc900bc.b83bb","type":"mqtt-broker","z":"","name":"192.168.2.117 (PrivCert)","broker":"192.168.2.117","port":"8883","tls":"d525c1aa.03cac","clientid":"nodered","usetls":true,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"d525c1aa.03cac","type":"tls-config","z":"","name":"192.168.2.117 (PrivCert)","cert":"","key":"","ca":"","certname":"client.pem","keyname":"","caname":"","servername":"","verifyservercert":false}]
Shouldn't you mention that one also needs to install the fakeroku node ?
Oh absolutely right, it is the wrong link. I tried it with harmony-websocket before I used Fakeroku. I will change the link. Thank you!
You only need node-red-contrib-fakeroku
