Lost connection to server when deploy flex server
When I try and deploy the below node, node-red loses its connection.
I get the following on the terminal.
Any ideas?
using the following
Thanks!
looks like a bug in that lativ node - may be best to try to contact the author direct though they don't seem to have provided a link to the github or other repository. Either that or maybe try not to use that set of nodes.
Yes there maybe is a bug.
I uninstalled NR using the following instructions and reinstalled it.
Works ok after that.
