help!
im was playing opc ua with tia portal everything was fine and then this happened for some reason after some seconds, it says the server crasheh, ive tried to repair node sj, then restart the computer, still the same problem
start with node-red --safe, this will get you into the flow editor where you can fix your flow and deploy.
Old version? Or nodeId is malformed, missing datatype= ??
Thanks guys, i fixed i deleted the opc ua pallet from the hard drive and re installed it from node red. So all is good
