Running NR on a Ubuntu system (X86 cpu) and I've just noticed I don't have pallet manager in my menu - I've been running NR for a coupe of years on the same computer and I've not had this problem before - any suggestions?
Usually happens when npm is not installed. What does npm -v show?
it shows V10.5.0 and then it goes on to say "it's known not to run on JS V14 .........." and a lot of other blurb
What does node -v show?
And do you have nvm or n or any other node version manager installed?
it shows 14.21.3
not sure about nvm, how do I check
You really should be on v18 at minimum. 14 is end of life (unsupported) as is 16.
Did you install a version manager?
Enter nvm
Enter n
Do you get anything?
Both options return command not found
There is your answer.
What about n & nvm?
Sorry. I misread your response.
I recommend updating everything
I don't understand what you mean - what about it? It appears they are not installed.
Anyway I looks as though I'll have to try and update everything, not sure how to do that but I expect I can Goggle it. I'll back up all my flows first
Thanks for your help Steve
I think our replies crossed
I recommend you update using the official script & add --node18 to the end of the command.
Ok, thanks. I'll give it a go once I've done the backups
With my experience with Linux I expect the air will turn blue ![]()
Thanks again for your help
