I am an ol' guy, over 70 and took to NodeRed V2.0 about a week ago. I have developed a functional link up of MQTT to Node Red V2.0 to and from influxDB V2.0 Running over 80 data points into multiple (8) multi line graphs, and 50 LED indicators and Text box numerical values. What phenomenal software!
Now it is time to control my system in the opposite direction and I am totally stumped by how to change the button color of the switch in the off and on conditions.
I have worked on this for 8 hours with AI to no solution, and have searched you site, but could not find V2.0 solutions. In the code below #1 works, 2 and 3 do not change the white and teal colors that are default. This code is in a template node.
If one of you guru's could help this ol' guy or point me in the right direction, I sure would appreciate it.
All the best,
Dave
//Works!
// 1.Change the background selection track when checked/unchecked
.custom-switch .v-selection-control__wrapper .v-switch__track {
background-color: #505050 !important; //This changed the track of the button OK
opacity: 0.6;
//Does NOT work
// 2. Target the circle ONLY when the switch is OFF
.custom-switch .v-selection-control:not(.v-selection-control--selected) .v-switch__thumb {
background-color: #00ffcc !important;
//Does NOT work
// 3. Target the circle ONLY when the switch is ON //
.custom-switch .v-selection-control--selected .v-switch__thumb {
background-color: #ff0055 !important;
If you open your browsers console, you can test your selectors to make sure they target the correct thing using $("<the selector>") e.g. $('.v-selection-control--selected') or $('.custom-switch .v-switch__thumb') (if $("xxx") errors, try $$("xxx"))
Steve, you did not just give me a fish, you are teaching me to fish! I love learning!
Yes, using Node Red Dashboard 2.0 and Node Red V5.0.0 running in a container on a Synology NAS
I never knew about vuetify controls! Thank you for that, and the web site... so much more to learn... but that is good
Thank you for not only the changes, but the link to the Vuetify Playground with the demo
4)"If you open your browsers console".. I can tell that is in vuetify, but I don't know exactly where? The playground.? A subset of the playground? I could not replicate it.
5)When I pasted the code in the example of #4 above into a template node, it did create a switch but without (it seems to me) all the capability that is in the switch node. It did also change the character of the switch I created with a switch node. So I had 2 switches on my group.
If I only put the following in a template node, it changed my switch, but used up space in the group
<style>
/* Target the circle ONLY */
.custom-switch .v-switch__thumb {
--v-theme-surface-bright: 100, 120, 210 !important;
/* off colour */
--v-theme-primary: 255, 0, 80 !important;
/* on colour */
</style>
Am I putting things in the wrong space/node/etc?
Not having my colleagues around any more, when I hit these simple roadblocks...you don't even know what to search for to get the answer,,, as you know, and I am learning, the LLM is overconfident, and when it gets lost it goes forever down a rat hole.
Thank you for helping this ol' guy!
All the best,
Dave
Also this restriction on comments bit me! (Added for others that are starting out)
1. **Function Nodes**: You can use `//` for single-line comments or `/* */` for multi-line comments inside your JavaScript code.
2. **JSON/Template Nodes**: If you are working inside JSON fields or standard template nodes, `//` comments are **not allowed** because standard JSON does not support them.
Just want to thank you all again! You got me over the hump. 80 data streams, 15 control functions, 14 deployed ESP8266 nodes, 4 tabs on iphone all working to perfection. System: MQTT><Tailscale VPN. Running on Synology DS425+ like a dream... like a dream.
