Map() through array of objects and do math on them
I have this array of objects coming in on a msg.payload.
(the actual array has lots of other key:value pairs that I'm not interested in
  "id": "99999",
  "signal": "voltage1",
  "timeseries": [
         "time": 1664553600000,
         "value": 2
         "time": 1664553700000,
         "value": 4
  "id": "99999",
  "signal": "voltage2",
  "timeseries": [
         "value": 3
         "value": 1
  "id": "99999",
  "signal": "current",
  "timeseries": [
         "value": 5
         "value": 4
I want to match up the timestamps and do ("voltage1" + "voltage2") * "current"
Then I want to output a new array that has the result for each timestamp.
I started with the map() function, and got here:
const input = msg.payload;
const output = input.map(signal => {
    const container = {};
    container["id"] = signal.id;
    container["signal"] = signal.signal;
    container["timeseries"] = signal.timeseries;
    return container;
msg.payload = output;
this does return me new arrays with only the information I'm interested in. But I'm a bit lost on how to do the math operations. I've found math.max() math.sum(), but nothing much more complex.
Anyone have pointers?
Example function node:
// function to find signal and timestamp
const f = (key, t) => i.find(v => v.signal === key).timeseries.find(x => x.time === t).value
const i = msg.payload
const results = []
// get array all of timestamps - assuming voltage1 timestamp also exist for voltage2 and current
const timestamps = i.find(v => v.signal === 'voltage1').timeseries.map( k=>k.time )
// loop through all timestamps and push result to results array
timestamps.forEach(t => {
        const v1 = f('voltage1', t)
        const v2 = f('voltage2', t)
        const c = f('current', t)
        const result = (v1 + v2) * c
        // key will be the timestamp
        results.push({ [t]: result })
msg.results = results
output:
    "1664553600000": 25
    "1664553700000": 20
@bakman2 thank you so much.
This is possibly the most helpful forum on the entire internet thanks to contributors like you. I just learned more about Javascript in 5 minutes than in the last 5 months. Big kudos!
