Hi everyone,
I am getting stuck on creating an object from an object of objects.
Of each msg.payload.vessels I want to grab MMSI, Speed etc, but my function node is not doing what I expected it to do, besides perhaps creating some with some of you .
flows .json (42.3 KB)
any advise is appreciated
E1cid
30 May 2022 15:47
2
First I would say can you sort the inject payload to as is has some oddities (bad names for properties)
Second msg.payload.vessels is not an array, so you may want to use Object.values to make it one.
example
const newMsg = {payload:[]};
const payload = Object.values(msg.payload.vessels);
for (var i = 0; i < payload.length; i++) {
newMsg.payload[i] = {
"mmsi": payload[i].mmsi,
"SOG": payload[i].navigation.speedOverGround
msg = newMsg;
This only does one of the objects from the object.
It only does the first one, it doesn't loop.
E1cid
30 May 2022 16:18
4
It loops and outputs an array with 16 elements. Please describe exactly the output you require.
Output
[{"mmsi":"246221000","SOG":0},{"mmsi":"244710681","SOG":2.3664450439438554},{"mmsi":"244130293","SOG":2.6236673313290573},{"mmsi":"244010086","SOG":2.675111788806098},{"mmsi":"244770559","SOG":0.7202224046785647},{"mmsi":"244690278","SOG":1.9548893841275328},{"mmsi":"244830937","SOG":3.1895563635765014},{"mmsi":"244002105","SOG":2.1606672140356946},{"mmsi":"370110000","SOG":3.6011120233928238},{"mmsi":"244368000","SOG":3.704000938346905},{"mmsi":"244077624","SOG":0},{"mmsi":"244020081","SOG":0.051444457477040344},{"mmsi":"244770433","SOG":1.49188926683417},{"mmsi":"244650640","SOG":2.675111788806098},{"mmsi":"244057950","SOG":0},{"mmsi":"205775000","SOG":2.726556246283138}]
I am getting the msg.payload.vessels from a TCP node.
As E1cid mentioned, some have bad properties.
How can I skip or overwrite undefined?
I have tried this, but no luck:
"MMSI": payload[i].mmsi,
"Name": payload[i].name,
"SOG": (payload[i].navigation.speedOverGround.value===undefined ? payload[i].navigation.speedOverGround.value: 0),
"COG": (payload[i].navigation.courseOverGroundTrue.value===undefined ? payload[i].navigation.courseOverGroundTrue.value: 0)
msg = newMsg;
I don't mind writing 0 or skipping an item.
E1cid
30 May 2022 19:17
7
The error you get is that navigation.courseOverGroundTrue doe not exist so when you try to look for value it throws an error as the prior property does not exist. So your check should be on the prior property or may be multiple conditionals.
"SOG": (payload[i].navigation.speedOverGround ? payload[i].navigation.speedOverGround.value : 0),
"COG": (payload[i].navigation.courseOverGroundTrue ? payload[i].navigation.courseOverGroundTrue.value : 0)
msg = newMsg;
Turns out that sometimes not only a navigation.speedOverGround or navigation.courseOverGround is missing, but the whole .navigation is missing.
I have try to bypass that one that has the missing .navigation with:
if (newMsg.payload[i] != undefined){
{if (newMsg.payload[i].navigation != undefined)
"SOG": (payload[i].navigation.speedOverGround ? payload[i].navigation.speedOverGround.value : "--,-"),
"COG": (payload[i].navigation.courseOverGroundTrue ? payload[i].navigation.courseOverGroundTrue.value : "--,-"),
"HDG": (payload[i].navigation.headingTrue ? payload[i].navigation.headingTrue.value : "--,-"),
"Longitude": (payload[i].navigation.position.value ? payload[i].navigation.position.value.longitude : "Undefined"),
"Latitude": (payload[i].navigation.position.value ? payload[i].navigation.position.value.latitude : "Undefined"),
"Status": (payload[i].navigation.state ? payload[i].navigation.state.value : "Undefined"),
"Destination": (payload[i].navigation.destination ? payload[i].navigation.destination.commonName.value : "Undefined"),
"VHF": (payload[i].communication ? payload[i].communication.callsignVhf : "Undefined")
msg = newMsg;
But that gives me:
The injectnode is a copy of the object I receive. The second from last MMSI is giving me the headache.
flows.json (344.7 KB)
E1cid
31 May 2022 07:19
9
I have not imported your latest, as the inject object is just to large, you would do better removing most vessels and making it more manageable
Possible example
newMsg.payload[i] = {};
newMsg.payload[i].MMSI = payload[i].mmsi;
newMsg.payload[i].Name = payload[i].name;
if (payload[i].navigation){
newMsg.payload[i].SOG = (payload[i].navigation.speedOverGround ? payload[i].navigation.speedOverGround.value : "--,-");
newMsg.payload[i].COG = (payload[i].navigation.courseOverGroundTrue ? payload[i].navigation.courseOverGroundTrue.value : "--,-");
newMsg.payload[i].HDG = (payload[i].navigation.headingTrue ? payload[i].navigation.headingTrue.value : "--,-");
if(payload[i].communication){
newMsg.payload[i].VHF = (payload[i].communication ? payload[i].communication.callsignVhf : "Undefined");
msg = newMsg;
I did say you might require multiple conditionals.
Thanks @E1cid , I'm learning a lot here.
After lots of trying, I got this to work just now;
if (payload[i].hasOwnProperty("navigation")){
msg = newMsg;
This way I skip the whole object.
