I work on a system that sends notifications when a job is completed or fails. It does not send a notification if its stuck. So I am using the email Node to receive the completed email, but also the inject set to a time just after I should have received the email. I then use the Wait-paths node to interpret which comes first.
my issue now is I can not access the msg.object to the level of Paths, my hop was to use the split node to trigger my next part of the flow which is the GPIO pins of my pi
Is there a node that will do what I am trying to do out of the box?
or can you help me get to the values I need ?
the values are
trigg (this is the Path) and 2 is the value of the message from trigg
email(this is the other parth) and 1 is the value of the message from email
The link below will show you how you can use the Change node to move the bit you want into the payload. However I am not sure if that is what you want to do. Read that section anyway as it tells you about message contents then if you are still stuck come back and explain what you want to do with trig and email. https://nodered.org/docs/user-guide/messages
I would feed both email and the inject into a function node. In the function node, when the email is received then save the current timestamp in the node-context and do not send on a message. Also in that function node when the inject is received (you can use different topic values to identify which message is which) then you can check the timestamp of the last email and if it is not recent then do whatever you need to do.
