Messed up dashboard layout
Hello All,
Sorry for writing in "Bad English".
I have 2 flows with a "messed up dashboard", they were just working fine till now.
One Node Red is running locally on a Raspberry Pi, the other is running on a free Ubuntu instance on the Google free tier platform.
Some Ideas?
I added 2 screenshots.
Welcome to the forum @MichelDeMeester
Do you mean you have two separate systems that were working, then suddenly they are not working, but you did nothing to them that could have caused it?
Hello Colin,
Yes indeed, I used several browsers to test including android phone, everywhere this strange behavior.
The node red running on the Google VM Ubuntu instance, I was able to solve the problem by restarting the node red service (systemctl restart node-red).
The node red, running local in my network (used for testing flows before publish them) on a RPI is still producing the scattered dashboard, even after rebooting.
It seems that the complete link to the mgs.payload is displayed instead of the values.
Thanks for thinking along
Michel
Assuming that you installed node red using the recommended install script, then stop and restart node-red using
node-red-stop
node-red-start
Note the dashes, it is not node-red start, and copy/paste the full startup log here please, copy/paste, not a screenshot.
Hi Colin,
Yesterday, I updated node-red on the RPI using:
After updating, I wasn't even able to connect to the server Node-red server anymore.
This morning, stopping and starting node-red solved the problem (the dashboard looks fine again) and gave me this output:
Start Node-RED
Once Node-RED has started, point a browser at http://10.99.98.11:1880
On Pi Node-RED works better with the Firefox or Chrome browser
Use   node-red-stop                          to stop Node-RED
Use   node-red-start                         to start Node-RED again
Use   node-red-log                           to view the recent log output
Use   sudo systemctl enable nodered.service  to autostart Node-RED at every boot
Use   sudo systemctl disable nodered.service to disable autostart on boot
To find more nodes and example flows - go to http://flows.nodered.org
Starting as a systemd service.
7 Mar 07:34:53 - [info]
Welcome to Node-RED
7 Mar 07:34:53 - [info] Node-RED version: v4.0.9
7 Mar 07:34:53 - [info] Node.js  version: v18.17.1
7 Mar 07:34:53 - [info] Linux 6.1.21-v7+ arm LE
7 Mar 07:34:57 - [info] Loading palette nodes
7 Mar 07:35:02 - [info] Dashboard version 3.5.0 started at /ui
7 Mar 07:35:06 - [info] Settings file  : /home/michel/.node-red/settings.js
7 Mar 07:35:06 - [info] Context store  : 'default' [module=memory]
7 Mar 07:35:06 - [info] User directory : /home/michel/.node-red
7 Mar 07:35:06 - [warn] Projects disabled : editorTheme.projects.enabled=false
7 Mar 07:35:06 - [info] Flows file     : /home/michel/.node-red/flows.json
7 Mar 07:35:06 - [info] Server now running at http://127.0.0.1:1880/
7 Mar 07:35:06 - [warn] Using unencrypted credentials
7 Mar 07:35:06 - [info] Starting flows
7 Mar 07:35:07 - [info] Started flows
7 Mar 07:35:08 - [info] [mqtt-broker:la66-usb-rangetest] Connected to broker: mq                                  tt://eu1.cloud.thethings.network:1883
7 Mar 07:35:08 - [info] [mqtt-broker:jff-garagedoor] Connected to broker: mqtt:/                                  /eu1.cloud.thethings.network:1883
Thanks for helping me solving the problem,
Michel
