Migrating to Dashboard 2.0 - Popup Windows with fields
On my dashboard 1.0, I am using ui_template to display a popup windows by clicking on a ui_button. The UI_button send to the template several data to be displayed or corrected by the end user. I tried the same code ( HTML, Java) and this is not working, it's make Chrome crashing.
Then I wnt on Vuetify site and I find a very good exemple of what I need (Dialog component — Vuetify)
If I used the original code from Vuetify and leave the vButton embeded the popup working fine.
Because I need to send payload to the popup and trigger the popup windows display, I removed from the original Vuetify code :
    v-button  ( <v-btn
      class="text-none font-weight-regular"
      prepend-icon="mdi-account"
      text="Edit Profile"
      variant="tonal"
      v-bind="activatorProps"
    ></v-btn> )
I need to trigger the popup windows with the UI_button because, as I said, I need to send data to the popup window as well as the trigger to get it popup.
I tried several things and I can't get it to popup.
The UI_button send this msg.payload : "flowfuse-button-clicked"
Code in the UI_template:
<template>
  <v-app>
    <v-container>
      <!-- Vuetify Dialog -->
      <v-dialog v-model="dialog" max-width="500px">
        <v-card>
          <v-card-title>
            Dialog Title
          </v-card-title>
          <v-card-text>
            This is the dialog content.
          </v-card-text>
          <v-card-actions>
            <v-btn color="primary" text @click="dialog = false">
              Close
            </v-btn>
          </v-card-actions>
        </v-card>
      </v-dialog>
    </v-container>
  </v-app>
</template>
<script>
export default {
  data() {
    return {
      dialog: false, // State to control the dialog visibility
  mounted() {
    // Listen for the FlowFuse button click event
    EventBus.$on('flowfuse-button-clicked', this.openDialog);
  methods: {
    openDialog() {
      this.dialog = true; // Open the dialog
  beforeDestroy() {
    // Clean up the event listener
    EventBus.$off('flowfuse-button-clicked', this.openDialog);
</script>
<style>
/* Add any styles you need here */
</style>
If anyone have an idea what to do, it will be very appreciated
Best
Yves
To have "something happen when a message arrives" (in your case show a dialog), you can use 1 of 2 methods detailed in the section Receiving Data. in this instance, option 2 seems like the right choice.
Here is a quick demo of that:
chrome_LAZRm4mjxd
[{"id":"f65d3a7f47e32c15","type":"ui-template","z":"3642c7ee286f9c17","group":"","page":"","ui":"910f5c9dea6a3de4","name":"","order":0,"width":0,"height":0,"head":"","format":"<template>\n    <v-sheet class=\"mx-auto\" width=\"300\">\n         <v-dialog v-model=\"dialog\" max-width=\"500px\">\n            <v-form @submit.prevent>\n                <v-card>\n                    <v-card-title>\n                        <v-text-field v-model=\"firstName\" label=\"First name\"></v-text-field>\n                        <v-text-field v-model=\"feedback\" label=\"Feedback\"></v-text-field>\n                    </v-card-text>\n                    <v-card-actions>\n                        <v-btn @click=\"onSubmit()\">Submit</v-btn>\n                    </v-card-actions>\n                </v-card>\n            </v-form>\n        </v-dialog>\n    </v-sheet>\n</template>\n\n<script>\n    export default {\n        data() {\n            return {\n                dialog: false,\n                firstName: null,\n                feedback: null\n            }\n        },\n        mounted () {\n            console.log('hello from mounted')\n            this.$socket.on('msg-input:' + this.id, (msg) => { \n                console.log('hello from template')\n                if (msg && msg.topic === \"edit\") {\n                    this.dialog = true // open it\n                    this.firstName = msg.payload.firstName\n                    this.feedback = msg.payload.feedback\n                }\n             })\n        },\n        methods: {\n            onSubmit: function () {\n                const payload = {}\n                this.dialog = false // close it\n                payload.firstName = this.firstName\n                payload.feedback = this.feedback\n                this.send({ payload })\n            }\n        }\n    }\n</script>\n","storeOutMessages":true,"passthru":false,"resendOnRefresh":true,"templateScope":"widget:ui","className":"","x":1590,"y":960,"wires":[["0fe46c457a3b3741"]]},{"id":"0fe46c457a3b3741","type":"debug","z":"3642c7ee286f9c17","name":"debug 51","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1640,"y":1040,"wires":[]},{"id":"f74371bcef1a490c","type":"inject","z":"3642c7ee286f9c17","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"edit","payload":"{}","payloadType":"json","x":1450,"y":920,"wires":[["f65d3a7f47e32c15"]]},{"id":"10d6a1c1c79fd895","type":"inject","z":"3642c7ee286f9c17","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"edit","payload":"{\"firstName\": \"harry\", \"feedback\": \"not good\"}","payloadType":"json","x":1450,"y":1000,"wires":[["f65d3a7f47e32c15"]]},{"id":"910f5c9dea6a3de4","type":"ui-base","name":"My Dashboard","path":"/dashboard","includeClientData":true,"acceptsClientConfig":["ui-notification","ui-control"],"showPathInSidebar":false,"navigationStyle":"default"}]
Thanks a lot Steve, I was looking without seeing .. it is exactyle what I need...
have a great day
