I've been experimenting with the Aedes MQTT broker, but have run into an issue where i receive a yellow warning message after deploying changes that reads "Flows stopped due to missing node times: aedes broker"
I have already tried removing the node and re-installing the, while performing multiple reboots of the pi running NR along the way. I even removed all MQTT nodes and deleted the MQTT server before re-installing. But... the issue doesn't want to go away... So, below is a trace log of NR starting and changes being deployed that I'm hoping someone can use to help point me in the right direction...
Welcome to Node-RED
27 Dec 20:48:28 - [info] Node-RED version: v2.1.4
27 Dec 20:48:28 - [info] Node.js version: v14.18.2
27 Dec 20:48:28 - [info] Linux 5.10.63-v7+ arm LE
27 Dec 20:48:31 - [info] Loading palette nodes
27 Dec 20:48:32 - [debug] Module: node-red-contrib-aedes 0.6.0 /home/astroberry/.node-red/node_modules/node-red-contrib-aedes
27 Dec 20:48:32 - [debug] Module: node-red-contrib-metric-per-topic 0.2.0 /home/astroberry/.node-red/node_modules/node-red-contrib-metric-per-topic
27 Dec 20:48:32 - [debug] Module: node-red-contrib-mqtt-broker 0.2.9 /home/astroberry/.node-red/node_modules/node-red-contrib-mqtt-broker
27 Dec 20:48:32 - [debug] Module: node-red-contrib-play-audio 2.5.0 /home/astroberry/.node-red/node_modules/node-red-contrib-play-audio
27 Dec 20:48:32 - [debug] Module: node-red-contrib-python-function 0.0.5 /home/astroberry/.node-red/node_modules/node-red-contrib-python-function
27 Dec 20:48:32 - [debug] Module: node-red-contrib-rpi-imagecapture 0.0.2 /home/astroberry/.node-red/node_modules/node-red-contrib-rpi-imagecapture
27 Dec 20:48:32 - [debug] Module: node-red-contrib-rpi-shutdown 0.0.2 /home/astroberry/.node-red/node_modules/node-red-contrib-rpi-shutdown
27 Dec 20:48:32 - [debug] Module: node-red-contrib-ui-digital-display 1.0.3 /home/astroberry/.node-red/node_modules/node-red-contrib-ui-digital-display
27 Dec 20:48:32 - [debug] Module: node-red-dashboard 3.1.3 /home/astroberry/.node-red/node_modules/node-red-dashboard
27 Dec 20:48:32 - [debug] Module: node-red-node-pi-gpio 2.0.1 /home/astroberry/.node-red/node_modules/node-red-node-pi-gpio
27 Dec 20:48:32 - [debug] Module: node-red-node-ping 0.3.1 /home/astroberry/.node-red/node_modules/node-red-node-ping
27 Dec 20:48:32 - [debug] Module: node-red-node-random 0.4.0 /home/astroberry/.node-red/node_modules/node-red-node-random
27 Dec 20:48:32 - [debug] Module: node-red-node-serialport 0.15.0 /home/astroberry/.node-red/node_modules/node-red-node-serialport
27 Dec 20:48:32 - [debug] Module: node-red-node-smooth 0.1.2 /home/astroberry/.node-red/node_modules/node-red-node-smooth
27 Dec 20:48:41 - [info] Dashboard version 3.1.3 started at /ui
27 Dec 20:48:42 - [warn] ------------------------------------------------------
27 Dec 20:48:42 - [warn] [node-red-contrib-aedes/aedes-mqtt-broker] Error: Could not locate the bindings file. Tried:
â /home/astroberry/.node-red/node_modules/snappy/build/binding.node
â /home/astroberry/.node-red/node_modules/snappy/build/Debug/binding.node
â /home/astroberry/.node-red/node_modules/snappy/build/Release/binding.node
â /home/astroberry/.node-red/node_modules/snappy/out/Debug/binding.node
â /home/astroberry/.node-red/node_modules/snappy/Debug/binding.node
â /home/astroberry/.node-red/node_modules/snappy/out/Release/binding.node
â /home/astroberry/.node-red/node_modules/snappy/Release/binding.node
â /home/astroberry/.node-red/node_modules/snappy/build/default/binding.node
â /home/astroberry/.node-red/node_modules/snappy/compiled/14.18.2/linux/arm/binding.node
27 Dec 20:48:42 - [info] Settings file : /home/astroberry/.node-red/settings.js
27 Dec 20:48:42 - [info] Context store : 'default' [module=memory]
27 Dec 20:48:42 - [info] User directory : /home/astroberry/.node-red
27 Dec 20:48:42 - [warn] Projects disabled : editorTheme.projects.enabled=false
27 Dec 20:48:42 - [info] Flows file : /home/astroberry/.node-red/flows.json
27 Dec 20:48:42 - [info] Server now running at http://127.0.0.1:1880/
27 Dec 20:48:42 - [debug] loaded flow revision: 94ee9fce362f3ff4306de24c4c921e3e
27 Dec 20:48:42 - [debug] red/runtime/nodes/credentials.load : no user key present
27 Dec 20:48:42 - [debug] red/runtime/nodes/credentials.load : using default key
27 Dec 20:48:42 - [debug] red/runtime/nodes/credentials.load : keyType=system
your credentials.
27 Dec 20:48:42 - [trace] runtime event: {"id":"runtime-state","retain":true}
27 Dec 20:48:42 - [trace] runtime event: {"id":"runtime-deploy","payload":{"revision":"94ee9fce362f3ff4306de24c4c921e3e"},"retain":true}
27 Dec 20:48:42 - [info] Waiting for missing types to be registered:
27 Dec 20:48:42 - [info] - aedes broker
27 Dec 20:48:42 - [trace] runtime event: {"id":"runtime-state","payload":{"error":"missing-types","type":"warning","text":"notification.warnings.missing-types","types":["aedes broker"]},"retain":true}
27 Dec 20:48:42 - [trace] comms.open 6A2FWOBurYD4LSuGzEdbqwg1um1co2k2h8B0+2EQStU=
27 Dec 20:49:37 - [trace] utils.writeFile - copied /home/astroberry/.node-red/flows.json TO /home/astroberry/.node-red/.flows.json.backup
27 Dec 20:49:37 - [trace] utils.writeFile - written content to /home/astroberry/.node-red/flows.json.$$$
27 Dec 20:49:37 - [trace] utils.writeFile - renamed /home/astroberry/.node-red/flows.json.$$$ to /home/astroberry/.node-red/flows.json
27 Dec 20:49:37 - [debug] saved flow revision: 44fba06ed053541db2a0f8c91467f91e
27 Dec 20:49:37 - [info] Stopping flows
27 Dec 20:49:37 - [info] Stopped flows
27 Dec 20:49:37 - [info] Waiting for missing types to be registered:
27 Dec 20:49:37 - [info] - aedes broker
27 Dec 20:49:37 - [trace] runtime event: {"id":"runtime-state","payload":{"error":"missing-types","type":"warning","text":"notification.warnings.missing-types","types":["aedes broker"]},"retain":true}
27 Dec 20:49:37 - [trace] runtime event: {"id":"runtime-deploy","payload":{"revision":"44fba06ed053541db2a0f8c91467f91e"},"retain":true}
27 Dec 20:59:24 - [trace] utils.writeFile - copied /home/astroberry/.node-red/flows.json TO /home/astroberry/.node-red/.flows.json.backup
27 Dec 20:59:24 - [trace] utils.writeFile - written content to /home/astroberry/.node-red/flows.json.$$$
27 Dec 20:59:24 - [trace] utils.writeFile - renamed /home/astroberry/.node-red/flows.json.$$$ to /home/astroberry/.node-red/flows.json
27 Dec 20:59:24 - [debug] saved flow revision: 94ee9fce362f3ff4306de24c4c921e3e
27 Dec 20:59:24 - [info] Stopping flows
27 Dec 20:59:24 - [info] Stopped flows
27 Dec 20:59:24 - [info] Waiting for missing types to be registered:
27 Dec 20:59:24 - [info] - aedes broker
27 Dec 20:59:24 - [trace] runtime event: {"id":"runtime-state","payload":{"error":"missing-types","type":"warning","text":"notification.warnings.missing-types","types":["aedes broker"]},"retain":true}
27 Dec 20:59:24 - [trace] runtime event: {"id":"runtime-deploy","payload":{"revision":"94ee9fce362f3ff4306de24c4c921e3e"},"retain":true}
