good morning, everyone
i'm trying to create a google TTS in nodered combined with home assistant tts.google_say service call but for some reason nodered does not display the entity_id field once i selected tts.google_say call service. If i select a different type of call service like light.turn_on for example, i have the option to pick out an entity_id.
You'll likely have to raise an issue on the home assistants GitHub for the HA nodes or bring it up on the home assistant forum (because the node-red maintainers don't develop those nodes - sorry)
thank you for taking the time to response. I'm using the "actions" AKA "call service" under home assistant node
ok thank you for pointing me in the right direction
