Google Assistant Voice Commands + NodeRed
Hi there!
Since IFTTT made it's service as subscription-based, I'm looking to find something to be able to simply trigger flows in Noder-Red through Voice Assistant.
Basically all I want, is whenever I say a specific phrase, a nodered node would just pick up on it (somewhat similar as to how Joao's Join-nodes work), and execute the flow.
Also, it would be nice if the assistant would be able to say back a specific phrase also.
Is it possible, and if it is, how should I go about it?
Thanks in advance,
Aaron
Although there are some restrictions node-red-contrib-googlehome (node) - Node-RED seems to work pretty well, and the developer @hardillb is likely to be adding a 'sensor' category to the node sometime soon.
That will enable us to ask the assistant about any sensors we are monitoring in node-RED.
There are other nodes that also could be used, although some are very difficult to setup.
Use google home routines to setup your phrase.
