hi need help
something went wrong in my node red and all the nodes now display the entity Id like (switch.102_2) instead the friendly name I gave them like (patio light ustairs-local). may be there is an index file that needs to be rebuild
I don't know how to fix
thx
Welcome to the forums @radames
First thing : export your flow and paste it here (removing any sensitive data).
we can then begin to see if there are any obvious issues.
JSON Here
I have never heard of this - but maybe some other members have
Can I check whether you are using Home Assistant?
yes using home assistant
I tried to uninstall and reinstall red node still the same
It is more likely that there is something wrong with home assistant and/or the home assistant nodes.
Few here use HA, finding it simpler to do everything in node-red, so you may be better asking on an HA forum.
I am using node red I installed it in home assistant and every thing is in node red, when I go into any of the call services in node red in entities display the entity Id like (switch.102_2) instead the friendly name I gave them like (patio light ustairs-local). may be there is an index file that needs to be rebuild
Hi @radames
This is an issue with Home Assistant (or It's Node RED Nodes) - this is nothing to do with Node RED.
as above - you need to seek support from the HA community
Just to amplify the previous comment a bit, the nodes you mention are running within node-red but they are supplied as part of the HA packaged version of node-red, they are not part of the normal node-red install. That is why we don't know much about them. The normal node-red install does not have the concept of Entities with IDs, they are a HA concept.
And to expand still further, Home Assistant installs Node-RED in its own way which seems to be poorly understood. Sadly, HA does seem to cause a lot of issues.
