I am having trouble to mix bar and line chart.
I have no trouble getting only bar or line chart only but when I tried to combine them it is not working.
This is what I'm trying to do but instead of yield I want Total output for Bar and Target Output as the line.
"id": "bb9f0674e767961b",
"type": "inject",
"z": "4e40fbd2a88aea91",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "10",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "Fetch data",
"payload": "",
"payloadType": "date",
"x": 180,
"y": 160,
"1126ebdf70946e27",
"166dab3687d4ac2c"
"id": "1126ebdf70946e27",
"type": "function",
"name": "function 8",
"func": "msg.payload = \"SELECT TOP (8) TimeDate, AlarmName, Value, Action, TagName FROM dbo.Alarms ORDER BY TimeDate DESC\";\n\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 400,
"y": 80,
"f904c1045e625f7d"
"id": "fb6f90abba60c543",
"type": "ui-table",
"group": "87bd5593e055a322",
"name": "Alarm",
"label": "",
"order": 1,
"width": "0",
"height": "0",
"maxrows": "0",
"passthru": false,
"autocols": true,
"showSearch": false,
"deselect": true,
"selectionType": "none",
"columns": [],
"mobileBreakpoint": "md",
"mobileBreakpointType": "defaults",
"action": "replace",
"x": 790,
"y": 80,
"id": "f904c1045e625f7d",
"type": "MSSQL",
"mssqlCN": "60c5e3d85f4c16dc",
"name": "Alarm",
"outField": "payload",
"returnType": 0,
"throwErrors": 1,
"query": "",
"modeOpt": "queryMode",
"modeOptType": "query",
"queryOpt": "payload",
"queryOptType": "editor",
"paramsOpt": "queryParams",
"paramsOptType": "none",
"rows": "rows",
"rowsType": "msg",
"parseMustache": true,
"params": [],
"x": 590,
"y": 80,
"fb6f90abba60c543"
"id": "8ce8136ac3316ddc",
"type": "function",
"name": "function 14",
"func": "msg.payload = \"SELECT TOP (1) RecipeName FROM dbo.Alarms ORDER BY TimeDate DESC\";\n\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 550,
"y": 160,
"e536d056e7b4ecbe"
"id": "e536d056e7b4ecbe",
"type": "MSSQL",
"name": "Recipe",
"returnType": 0,
"throwErrors": 1,
"query": "",
"rows": "rows",
"rowsType": "msg",
"params": [],
"x": 720,
"y": 160,
"948da202abdb9f85"
"id": "948da202abdb9f85",
"type": "function",
"name": "function 15",
"func": "let recipe = \"N/A\"; // This will be used as the CP_Model for MariaDB lookup\nlet fullRecipeName = \"N/A\";\n\nif (msg.payload && Array.isArray(msg.payload) && msg.payload.length > 0) {\n if (msg.payload[0] && typeof msg.payload[0].RecipeName === 'string') {\n fullRecipeName = msg.payload[0].RecipeName;\n // Extract the first part of the RecipeName to use as the lookup ID\n recipe = fullRecipeName.split(' ')[0]; \n }\n}\n\nmsg.payload = \"Model : \" + recipe;\n\nmsg.cpModelToLookup = recipe; \n\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 890,
"y": 160,
"52a6eb2324cbd228",
"7fe16e3597266f41",
"bb1ea618e7d2c48e"
"id": "52a6eb2324cbd228",
"type": "ui-text",
"group": "1f528672fb91aed2",
"order": 5,
"width": 0,
"height": 0,
"name": "Recipe Name :",
"label": "",
"format": "{{msg.payload}}",
"layout": "row-center",
"style": true,
"font": "Arial Black,Arial Black,Gadget,sans-serif",
"fontSize": "35",
"color": "#000000",
"wrapText": false,
"className": "",
"x": 1160,
"y": 160,
"id": "166dab3687d4ac2c",
"type": "delay",
"pauseType": "delay",
"timeout": "1",
"timeoutUnits": "seconds",
"rate": "1",
"nbRateUnits": "1",
"rateUnits": "second",
"randomFirst": "1",
"randomLast": "5",
"randomUnits": "seconds",
"drop": false,
"allowrate": false,
"outputs": 1,
"x": 380,
"y": 160,
"8ce8136ac3316ddc"
"id": "7fe16e3597266f41",
"type": "function",
"name": "Prepare MariaDB Query",
"func": "const cpModelFromMSSQL = msg.cpModelToLookup; \n\nif (cpModelFromMSSQL && cpModelFromMSSQL !== \"N/A\") {\n const cleanedLookupValue = cpModelFromMSSQL.replace('-', '');\n\n msg.topic = `\n SELECT CP_Model, Run_Rate_ADS, Committed_Output_Shift\n FROM uph_analysis \n WHERE REPLACE(CP_Model, '-', '') = '${cleanedLookupValue}';\n `;\n \n msg.cleanedLookupValue = cleanedLookupValue;\n\n} else {\n node.warn(\"CP Model to lookup in MariaDB is N/A or missing. Skipping MariaDB query.\");\n msg.topic = \"\"; \n return null; \n}\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 1110,
"y": 220,
"26e619e4003ed1f6"
"id": "26e619e4003ed1f6",
"type": "mysql",
"mydb": "6ef2625909603909",
"name": "Maria",
"x": 1350,
"y": 220,
"5c8762eb277310c4",
"9b6099afc152fc34",
"5e5ea5b53d5127ac"
"id": "5c8762eb277310c4",
"type": "function",
"name": "Format Target Speed",
"func": "const mariaDbData = msg.payload; // Result from MariaDB\nconst lookedUpModel = msg.cpModelToLookup; // The model we searched for (set by \"function 15\")\n\nif (mariaDbData && Array.isArray(mariaDbData) && mariaDbData.length > 0) {\n const result = mariaDbData[0]; // Assuming CP_Model is unique\n msg.payload = \"Target Speed: \" + (result.Run_Rate_ADS !== null ? result.Run_Rate_ADS : \"N/A\");\n} else {\n msg.payload = `Target Speed: N/A (for ${lookedUpModel})`;\n}\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 1560,
"y": 220,
"f2c161a882100432"
"id": "9b6099afc152fc34",
"type": "function",
"name": "Format Target Output",
"func": "const mariaDbData = msg.payload;\nconst lookedUpModel = msg.cpModelToLookup;\nlet targetOutputForDisplay = \"N/A\";\nlet numericTargetOutput = null;\n\nif (mariaDbData && Array.isArray(mariaDbData) && mariaDbData.length > 0) {\n const result = mariaDbData[0];\n if (result.Committed_Output_Shift !== null && typeof result.Committed_Output_Shift === 'number') {\n numericTargetOutput = result.Committed_Output_Shift;\n targetOutputForDisplay = numericTargetOutput.toLocaleString('en-US');\n }\n}\n\nflow.set(\"currentHourlyTarget\", numericTargetOutput);\n\nif (numericTargetOutput !== null) {\n msg.payload = \"Target Output: \" + targetOutputForDisplay;\n} else {\n msg.payload = `Target Output: N/A (for ${lookedUpModel})`;\n}\nreturn msg;\n/*const mariaDbData = msg.payload; \nconst lookedUpModel = msg.cpModelToLookup;\n\nif (mariaDbData && Array.isArray(mariaDbData) && mariaDbData.length > 0) {\n const result = mariaDbData[0];\n let output = \"N/A\";\n if (result.Committed_Output_Shift !== null && typeof result.Committed_Output_Shift === 'number') {\n output = result.Committed_Output_Shift.toLocaleString('en-US');\n }\n msg.payload = \"Target Output: \" + output;\n} else {\n msg.payload = `Target Output: N/A (for ${lookedUpModel})`;\n}\nreturn msg;*/",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 1560,
"y": 300,
"cc0edc1155221834"
"id": "f2c161a882100432",
"type": "ui-text",
"order": 7,
"width": 0,
"height": 0,
"name": "Target Speed",
"label": "",
"style": true,
"font": "",
"fontSize": "35",
"color": "#000000",
"wrapText": false,
"className": "",
"x": 1830,
"y": 220,
"id": "cc0edc1155221834",
"type": "ui-text",
"order": 9,
"width": 0,
"height": 0,
"name": "Target Output",
"label": "",
"style": true,
"font": "",
"fontSize": "35",
"color": "#000000",
"wrapText": false,
"className": "",
"x": 1820,
"y": 300,
"id": "079254a340d8e511",
"type": "debug",
"name": "debug 13",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"statusType": "auto",
"x": 1040,
"y": 560,
"id": "auto_inject_trigger_01",
"type": "inject",
"name": "Daily Total ",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "900",
"crontab": "",
"once": true,
"onceDelay": 0.1,
"topic": "triggerAutoDailyTotal",
"payload": "",
"x": 210,
"y": 500,
"auto_func_set_date_sql_01"
"id": "auto_func_set_date_sql_01",
"type": "function",
"name": "Set Current UTC Date & SQL",
"func": "const now = new Date();\n\nconst year = now.getUTCFullYear();\nconst month_0idx = now.getUTCMonth();\nconst day = now.getUTCDate();\n\nconst reportDateUTCObj = new Date(Date.UTC(year, month_0idx, day, 0, 0, 0, 0));\n\nconst dateForQuery = reportDateUTCObj.getUTCFullYear() + '-' +\n (reportDateUTCObj.getUTCMonth() + 1).toString().padStart(2, '0') + '-' +\n reportDateUTCObj.getUTCDate().toString().padStart(2, '0');\n\nconst startTimeSQL = `${dateForQuery} 00:00:00.000`;\nconst endTimeSQL = `${dateForQuery} 23:59:59.999`;\n\nmsg.payload = `\n SELECT\n [Time],\n SUM(Total) AS Total \nFROM\n dbo.batch\nWHERE\n [Time] >= CONVERT(datetime, '${startTimeSQL}', 120)\n AND [Time] <= CONVERT(datetime, '${endTimeSQL}', 120)\nGROUP BY\n [Time]\nORDER BY\n [Time] ASC;\n`;\n\nmsg.reportDateForUTCDay = reportDateUTCObj; \nconst displayDateForStatus = reportDateUTCObj.toLocaleDateString('en-GB', { timeZone: 'UTC' });\n\nnode.log(\"AutoDailyTotal: Querying for \" + displayDateForStatus + \" (UTC Day)\");\n\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 440,
"y": 500,
"auto_mssql_data_01"
"id": "auto_mssql_data_01",
"type": "MSSQL",
"mssqlCN": "8baf7e1e28030a6d",
"name": "Get Current Day Data",
"returnType": 0,
"throwErrors": "1",
"query": "",
"rows": "",
"rowsType": "msg",
"params": [],
"x": 740,
"y": 500,
"auto_func_calculate_sum_01",
"079254a340d8e511",
"36f6f7e1b733d31b"
"id": "auto_func_calculate_sum_01",
"type": "function",
"name": "Calc Auto Daily Sum (7AM-7PM UTC)",
"func": "const batchData = msg.payload;\nconst reportDateUTCObjInput = msg.reportDateForUTCDay;\n\nlet reportDateStringForDisplay = \"an unspecified UTC date\";\nlet reportDateUTCObj = null;\n\nif (reportDateUTCObjInput) {\n reportDateUTCObj = new Date(reportDateUTCObjInput);\n if (isNaN(reportDateUTCObj.getTime())) {\n reportDateUTCObj = null;\n } else {\n reportDateStringForDisplay = reportDateUTCObj.toLocaleDateString('en-GB', { timeZone: 'UTC' });\n }\n}\n\nif (!reportDateUTCObj) {\n msg.payload = \"Today's Total (7AM-7PM UTC): Error - Date Invalid\";\n node.warn(\"AutoDailySum Calc: Invalid date object received.\");\n return msg;\n}\n\nif (!Array.isArray(batchData)) {\n node.warn(\"AutoDailySum Calc: Input batchData is not an array for \" + reportDateStringForDisplay + \" (UTC).\");\n msg.payload = \"Today's Total (7AM-7PM UTC) for \" + reportDateStringForDisplay + \": Error fetching data\";\n return msg;\n}\n\nlet dailyTotalOutputSum = 0;\nlet dataFoundInTimeRange = false;\n\nbatchData.forEach((item, index) => {\n if (!item || typeof item.Time === 'undefined' || item.Total === null || typeof item.Total === 'undefined') {\n return;\n }\n const itemTime = new Date(item.Time);\n if (isNaN(itemTime.getTime())) {\n return;\n }\n\n // SQL already filters by day, but double-check for safety if needed (usually not with this setup)\n // if (itemTime.getUTCFullYear() !== reportDateUTCObj.getUTCFullYear() || ... ) return;\n\n const itemHourUTC = itemTime.getUTCHours();\n const itemTotal = parseFloat(item.Total);\n\n if (itemHourUTC >= 7 && itemHourUTC < 19) { // Sum for 07:00 UTC to 18:59 UTC\n if (!isNaN(itemTotal)) {\n dailyTotalOutputSum += itemTotal;\n dataFoundInTimeRange = true;\n }\n }\n});\n\nlet dailyTotalString;\nif (batchData.length === 0 && !dataFoundInTimeRange) { // No data returned from SQL at all for the day\n dailyTotalString = \"Current Output: No data\";\n} else if (!dataFoundInTimeRange) { // Data existed for the day, but none in the 7AM-7PM range\n dailyTotalString = \"Current Output: 0\";\n} else {\n dailyTotalString = \"Current Output: \" + dailyTotalOutputSum.toLocaleString();\n}\n\nmsg.payload = dailyTotalString;\nnode.log(\"AutoDailySum Calc: \" + msg.payload);\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 1050,
"y": 500,
"78a071dec8d0aca5"
"id": "78a071dec8d0aca5",
"type": "ui-text",
"order": 8,
"width": 0,
"height": 0,
"name": "Output",
"label": "",
"style": true,
"font": "",
"fontSize": "35",
"color": "#000000",
"wrapText": false,
"className": "",
"x": 1310,
"y": 500,
"id": "36f6f7e1b733d31b",
"type": "function",
"name": "Daily Hourly Chart Data",
"func": "const rawData = msg.payload;\n\n// --- Logic for data preparation ---\nif (!Array.isArray(rawData)) {\n node.status({ fill: \"red\", shape: \"ring\", text: \"Input data is not an array\" });\n // For Dashboard 2.0 ui-chart, send an empty valid structure\n msg.payload = { data: { labels: [], datasets: [] }, options: {} };\n return msg;\n}\n\nconst hourlyTotals = {};\nconst desiredHoursUTC = [7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18];\nconst xLabels = [\n \"7AM-8AM\", \"8AM-9AM\", \"9AM-10AM\", \"10AM-11AM\",\n \"11AM-12PM\", \"12PM-1PM\", \"1PM-2PM\", \"2PM-3PM\",\n \"3PM-4PM\", \"4PM-5PM\", \"5PM-6PM\", \"6PM-7PM\"\n];\n\ndesiredHoursUTC.forEach(hour => {\n hourlyTotals[hour] = 0;\n});\n\nlet dataFoundForChart = false;\nrawData.forEach(item => {\n if (!item || typeof item.Time === 'undefined' || item.Total === null || typeof item.Total === 'undefined') {\n return;\n }\n const itemTime = new Date(item.Time);\n if (isNaN(itemTime.getTime())) {\n return;\n }\n const itemHourUTC = itemTime.getUTCHours();\n if (itemHourUTC >= 7 && itemHourUTC < 19) { // UTC 7:00 to 18:59\n const itemTotal = parseFloat(item.Total);\n if (!isNaN(itemTotal)) {\n if (hourlyTotals.hasOwnProperty(itemHourUTC)) {\n hourlyTotals[itemHourUTC] += itemTotal;\n dataFoundForChart = true;\n }\n }\n }\n});\n\nconst actualOutputValues = [];\ndesiredHoursUTC.forEach(hour => {\n actualOutputValues.push(hourlyTotals[hour]);\n});\n\nconst committedHourlyTarget = flow.get(\"currentHourlyTarget\");\nlet targetOutputValues = new Array(xLabels.length).fill(null); // Default to null if no target\n\nif (committedHourlyTarget !== null && typeof committedHourlyTarget === 'number' && !isNaN(committedHourlyTarget)) {\n targetOutputValues = new Array(xLabels.length).fill(committedHourlyTarget);\n}\n\nif (!dataFoundForChart && rawData.length > 0 && committedHourlyTarget === null) {\n node.status({ fill: \"yellow\", shape: \"ring\", text: \"Actuals out of range, no target\" });\n} else if (!dataFoundForChart && committedHourlyTarget === null) {\n node.status({ fill: \"yellow\", shape: \"ring\", text: \"No actuals data, no target\" });\n} else {\n node.status({ fill: \"green\", shape: \"dot\", text: \"Combined chart data prepared\" });\n}\n\n// --- Structure for node-red-dashboard-2.0 ui-chart node ---\nmsg.payload = {\n data: {\n labels: xLabels,\n datasets: [\n {\n label: \"Hourly Output\", // BAR chart\n data: actualOutputValues,\n type: 'bar',\n backgroundColor: 'rgba(54, 162, 235, 0.5)', // Blue\n borderColor: 'rgb(54, 162, 235)',\n borderWidth: 1,\n yAxisID: 'yBar'\n },\n {\n label: \"Target Output\", // LINE chart\n data: targetOutputValues,\n type: 'line',\n fill: false,\n borderColor: 'rgb(255, 99, 132)', // Red\n tension: 0.1,\n yAxisID: 'yLine'\n }\n ]\n },\n options: {\n responsive: true,\n maintainAspectRatio: false,\n interaction: {\n mode: 'index',\n intersect: false,\n },\n stacked: false,\n plugins: {\n title: {\n display: true,\n text: 'Hourly Output vs. Target Output (7AM-7PM UTC)'\n },\n legend: {\n position: 'top',\n }\n },\n scales: {\n x: {\n display: true,\n title: {\n display: false,\n text: 'Time Slot'\n }\n },\n yBar: {\n type: 'linear',\n display: true,\n position: 'left',\n title: {\n display: true,\n text: 'Hourly Output'\n },\n beginAtZero: true\n },\n yLine: {\n type: 'linear',\n display: true,\n position: 'right',\n title: {\n display: true,\n text: 'Target Output'\n },\n grid: {\n drawOnChartArea: false,\n },\n beginAtZero: true\n }\n }\n }\n};\n\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 1030,
"y": 680,
"83683e185f1fee62"
"id": "83683e185f1fee62",
"type": "ui-chart",
"group": "efa1b65e2985d6df",
"name": "Hourly Bar Chart",
"label": "Output",
"order": 6,
"chartType": "bar",
"category": "Hourly Output",
"categoryType": "str",
"xAxisLabel": "Time Slot",
"xAxisProperty": "timeSlotLabel",
"xAxisPropertyType": "property",
"xAxisType": "category",
"xAxisFormat": "",
"xAxisFormatType": "auto",
"xmin": "",
"xmax": "",
"yAxisLabel": "Total Output",
"yAxisProperty": "actualOutputValue",
"yAxisPropertyType": "property",
"ymin": "0",
"ymax": "",
"bins": 10,
"stackSeries": false,
"pointShape": "line",
"pointRadius": 4,
"showLegend": true,
"removeOlder": "20",
"removeOlderUnit": "60",
"removeOlderPoints": "",
"colors": [
"#ff0000",
"#ff0000",
"#ff7f0e",
"#2ca02c",
"#a347e1",
"#d62728",
"#ff9896",
"#9467bd",
"#c5b0d5"
"textColor": [
"#000000"
"textColorDefault": false,
"gridColor": [
"#000000"
"gridColorDefault": false,
"width": "12",
"height": "19",
"className": "",
"interpolation": "linear",
"x": 1330,
"y": 680,
"40425edfe5540368"
"id": "40425edfe5540368",
"type": "debug",
"name": "debug 9",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 1660,
"y": 680,
"id": "5e5ea5b53d5127ac",
"type": "debug",
"name": "debug 4",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 1540,
"y": 360,
"id": "bb1ea618e7d2c48e",
"type": "debug",
"name": "debug 10",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 1080,
"y": 300,
"id": "87bd5593e055a322",
"type": "ui-group",
"name": "Alarm",
"page": "36d8747804871232",
"width": "6",
"height": 1,
"order": 2,
"showTitle": true,
"className": "",
"visible": "true",
"disabled": "false",
"groupType": "default"
"id": "60c5e3d85f4c16dc",
"type": "MSSQL-CN",
"tdsVersion": "7_4",
"name": "HMI",
"server": "10.183.175.8",
"port": "1433",
"encyption": true,
"trustServerCertificate": true,
"database": "HMI",
"useUTC": true,
"connectTimeout": "15000",
"requestTimeout": "15000",
"cancelTimeout": "5000",
"pool": "5",
"parseJSON": false,
"enableArithAbort": true,
"readOnlyIntent": false
"id": "1f528672fb91aed2",
"type": "ui-group",
"name": "Delta SA 03",
"page": "8ad4c897bc98235a",
"width": "4",
"height": 1,
"order": 3,
"showTitle": false,
"className": "",
"visible": "true",
"id": "6ef2625909603909",
"type": "MySQLdatabase",
"host": "127.0.0.1",
"port": "3306",
"db": "my_google_data",
"tz": "",
"charset": "UTF8"
"id": "8baf7e1e28030a6d",
"type": "MSSQL-CN",
"name": "i4.0",
"port": "1433",
"encyption": true,
"database": "i4.0",
"useUTC": true,
"pool": "5",
"parseJSON": false,
"id": "efa1b65e2985d6df",
"type": "ui-group",
"name": "Total Output and Average Yield",
"width": "12",
"height": 1,
"order": 13,
"showTitle": true,
"className": "",
"visible": "true",
"id": "36d8747804871232",
"type": "ui-page",
"ui": "e37b297fa64e1312",
"path": "/page1",
"icon": "home",
"layout": "grid",
"theme": "8796486dd6098e1f",
"breakpoints": [
"name": "Default",
"px": "0",
"cols": "3"
"name": "Tablet",
"px": "576",
"cols": "6"
"name": "Small Desktop",
"px": "768",
"cols": "9"
"name": "Desktop",
"px": "1024",
"cols": "12"
"order": 4,
"className": "",
"visible": true,
"disabled": false
"id": "8ad4c897bc98235a",
"type": "ui-page",
"name": "Main Page",
"path": "/page3",
"icon": "home",
"layout": "grid",
"breakpoints": [
"name": "Default",
"px": "0",
"cols": "3"
"name": "Tablet",
"px": "576",
"cols": "6"
"px": "768",
"cols": "9"
"name": "Desktop",
"px": "1024",
"cols": "12"
"order": 1,
"className": "",
"visible": "true",
"disabled": "false"
"id": "e37b297fa64e1312",
"type": "ui-base",
"name": "My Dashboard",
"path": "/dashboard",
"appIcon": "",
"includeClientData": true,
"acceptsClientConfig": [
"ui-notification",
"ui-control",
"ui-text",
"ui-text-input"
"showPathInSidebar": false,
"headerContent": "page",
"navigationStyle": "default",
"titleBarStyle": "fixed",
"showReconnectNotification": true,
"notificationDisplayTime": 1,
"showDisconnectNotification": true,
"allowInstall": true
"id": "8796486dd6098e1f",
"type": "ui-theme",
"name": "Theme 2",
"colors": {
"surface": "#0f0f0f",
"primary": "#050505",
"bgPage": "#767474",
"groupBg": "#d8d4d4",
"groupOutline": "#ffffff"
"sizes": {
"density": "default",
"pagePadding": "12px",
"groupGap": "4px",
"groupBorderRadius": "4px",
"widgetGap": "1px"
I tried to use only ui_template and but it just came out blank.
Any suggestion would be appreciated
