Mixed configuration property or optional?
Hi, I need to allow my node to accept one configuration node, but I want it to be one of many types.
I have matter-server and matter-aggregator and I would like the server property of my node to accept one from either lists. Is this possible?
If not, I would have to display two separate dropdowns and have the user pick from just one of them, but if I do that, Node-RED forces the user to select an option from each of the dropdowns even though I marked them as optional, ideas?
I guess if the above is not possible I will have to create my custom-made type dropdown, it's not a big deal but I would really like to do it only if there's not a better Node-RED standard way
Hi @FezVrasta
it isn't possible to have a single property to be selected from multiple types - you will need to have two separate properties.
It is possible to mark an config property as optional. For example, the HTTP Request node has an optional TLS config node property:
Thanks, I managed to make the optional property working, I'm not really sure why it kept complaining initially.
