Select multiple config nodes
Hello, i would like to know if there is a way to select multiple config nodes.
Something like the attribute multiple in a <select> tag.
You could probably have an editableList of config nodes.
Similar to how the change node does 1 or more entries
I was thinking about this feature aswell, i tried a little bit without succeeding on how to add a config node dynamically in the editableList.
The configuration node :
I get this :
Just a thought, instead of building a new node, why not contribute to the currently best and most supported MSSQL node?
node-red-contrib-mssql-plus
It would be simple to add dynamic capability to "connect" and "disconnect" on the fly without having to setup multiple configs.
Actually, I use this configuration node for testing purpose, i will swap with my configuration node once i found the solution to this problem.
