Optional Configuration Node
We are using multiple config nodes as part of a flow. Now we have a requirement which allows to pass id of a config node as part of msg.payload which made the config-node field optional. But, if no config node is chosen, a warning triangle is appearing on the node. Is it possible to specify config node is optional?
 defaults: {
            name: { value: 'WebService' },
            configRef: { type: 'host-details' }
Yes.
Add required: false to configRef
