Modify SMA sunny portal plant parameter
I have a photovoltaic plant with:
1 energy meter 2.0
1 sunny boy 5.0
1 Sunny Island 4.4
I would need to switch from node-red when activating battery charging as done from sunny portal.
Does anyone know how to change these parameters from node.red?
I have SMA integration in Home assistant, but these parameters are not accessible.
I have tried the node-webconnect, but they are all output parameters
Since modbus-tcp I have not seen these parameters, since they are accessible through the sunny portal, not directly from the inverters (SB and SI)
I put an image of the parameters that I would like to access from node.red-
Can somebody help me?
thank you
