Newbie here - hi. And I mean new I. New to Arduino/MQTT/Node-Red etc.
I’m running Arduino Mkr1010 controllers communicating via WiFi, MQTT to Node-Red on a laptop. All goes well running a single arduino. Can subscribe, publish etc. My problem occurs when I try with two arduinos. The second keeps disconnecting from MQTT.
Is there anything obvious I should try? Or would you prefer to see code etc?
Thanks Gunner - as it turns out you were correct. The code I had copied called the field Dev_Name and I presumed that referred to the device name of the MQTT broker. Wrong. Back on track now. Two working side by side. You bewdy!
