MQTT Connection works from Raspian but not Windows
Hi All,
I can make a succesful MQTT connection (TLS) from a RaspberryPi to an Azure IoT Hub using SAS Token authentication but when I try the identical flow from a Windows10 machine it won't connect. I'm just using the vanilla MQTT sender node rather than the specialised (Azure IoT) one but as I say, it works well from Raspian.
Hello and welcome to the forum.
This is just a guess, what with general lack of details provided... Firewall? Antivirus?
Perhaps more info will help us help you? Versions, errors, flow used... etc.
Thanks for the reply - in fact I've just figured out the problem. It was the SAS Token - it's generated with a lot of unnecessary stuff at the start that I had forgotten to remove.
