MQTT In: Disconnect after Re-Deploy
Hi all, I'm new to Node-RED but I think I'm facing a bug, or I'm misunderstanding something completely.
I am using MQTT-In to subscribe to a MQTT topic. I'm using Mosquitto 2.0 and MQTT 5.0 which I read is supported by Mosquitto 2.0. However, the same behavior can be observed when using MQTT 3.1.1 (I haven't tried 3.1 legacy). Both are in Docker containers.
With every re-deployment of my flow, if I change something within the flow itself (moving nodes is not enough), my MQTT-In node either connects or disconnects (if it's connected, it will disconnect, if it's disconnected, it will re-connect).
My flow looks as follows:
In the screenshot, it's connected. I then changed the debug node (re-named it) and triggered a re-deployment of the changed flow (I disabled all other flows for testing). This leads to the MQTT-In disconnecting:
Screenshot from 2022-12-01 09-04-09
For debugging, I increased Node-REDs log level to trace and Mosquittos log type to all.
Node-RED Logs:
[ === showing last few events for reference === ]
1 Dec 08:37:25 - [trace] [flow:8fe02e49cbc1e1e3]  e426ca5edb464827 | debug        |
1 Dec 08:37:25 - [trace] [flow:8fe02e49cbc1e1e3] ------------------|--------------|-----------------
1 Dec 08:37:25 - [trace] runtime event: {"id":"runtime-state","payload":{"state":"start","deploy":true},"retain":true}
1 Dec 08:37:25 - [info] Started modified flows
1 Dec 08:37:25 - [trace] runtime event: {"id":"runtime-deploy","payload":{"revision":"1cf16b3e9fa0bb14fde3cf71614001c7"},"retain":true}
1 Dec 08:37:25 - [info] [mqtt-broker:main] Connected to broker: mqtt://192.168.0.24:1883
[ === EVENT: RE-DEPLOY 1 - leading to disconnect === ]
1 Dec 08:46:56 - [trace] utils.writeFile - copied /data/flows.json TO /data/.flows.json.backup
1 Dec 08:46:56 - [trace] utils.writeFile - written content to /data/flows.json.$$$
1 Dec 08:46:56 - [trace] utils.writeFile - renamed /data/flows.json.$$$ to /data/flows.json
1 Dec 08:46:56 - [debug] saved flow revision: aec89413f9c5c5862827576f6d44d909
1 Dec 08:46:56 - [info] Stopping modified flows
1 Dec 08:46:56 - [debug] red/nodes/flows.stop : stopping flow : 8fe02e49cbc1e1e3
1 Dec 08:46:56 - [trace] [flow:8fe02e49cbc1e1e3] stop flow
1 Dec 08:46:56 - [trace] Stopping node debug:e426ca5edb464827
1 Dec 08:46:56 - [trace] Stopping node mqtt in:98eda388285104a1
1 Dec 08:46:56 - [debug] red/nodes/flows.stop : stopping flow : global
1 Dec 08:46:56 - [trace] [flow:global] stop flow
1 Dec 08:46:56 - [trace] Stopped node debug:e426ca5edb464827 (1ms)
1 Dec 08:46:56 - [trace] Stopped node mqtt in:98eda388285104a1 (1ms)
1 Dec 08:46:56 - [info] Stopped modified flows
1 Dec 08:46:56 - [trace] runtime event: {"id":"runtime-state","payload":{"state":"stop","deploy":true},"retain":true}
1 Dec 08:46:56 - [info] Updated flows
1 Dec 08:46:56 - [info] Starting modified flows
1 Dec 08:46:56 - [debug] red/nodes/flows.start : not starting disabled flow : 404a5fc31d9bfebc
1 Dec 08:46:56 - [debug] red/nodes/flows.start : not starting disabled flow : 80c0daf0d6dc14e8
1 Dec 08:46:56 - [debug] red/nodes/flows.start : not starting disabled flow : fefe4cc15c24e3f0
1 Dec 08:46:56 - [trace] [flow:global] start flow [global]
1 Dec 08:46:56 - [trace] [flow:global] ------------------|--------------|-----------------
1 Dec 08:46:56 - [trace] [flow:global]  id               | type         | alias
1 Dec 08:46:56 - [trace] [flow:global]  ec6252675c95ed29 | server       |
1 Dec 08:46:56 - [trace] [flow:global]  09a1213024a9a03b | influxdb     |
1 Dec 08:46:56 - [trace] [flow:global]  d50d0c9f.31e858  | tls-config   |
1 Dec 08:46:56 - [trace] [flow:global]  5d7e54ca.019d44  | influxdb     |
1 Dec 08:46:56 - [trace] [flow:global]  5a4cacde8bbbdebd | mqtt-broker  |
1 Dec 08:46:56 - [trace] [flow:8fe02e49cbc1e1e3] start flow [8fe02e49cbc1e1e3]
1 Dec 08:46:56 - [trace] [flow:8fe02e49cbc1e1e3] ------------------|--------------|-----------------
1 Dec 08:46:56 - [trace] [flow:8fe02e49cbc1e1e3]  id               | type         | alias
1 Dec 08:46:56 - [trace] [flow:8fe02e49cbc1e1e3]  98eda388285104a1 | mqtt in      |
1 Dec 08:46:56 - [trace] [flow:8fe02e49cbc1e1e3]  e426ca5edb464827 | debug        |
1 Dec 08:46:56 - [trace] runtime event: {"id":"runtime-state","payload":{"state":"start","deploy":true},"retain":true}
1 Dec 08:46:56 - [info] Started modified flows
1 Dec 08:46:56 - [trace] runtime event: {"id":"runtime-deploy","payload":{"revision":"aec89413f9c5c5862827576f6d44d909"},"retain":true}
1 Dec 08:46:56 - [info] [mqtt-broker:main] Disconnected from broker: mqtt://192.168.0.24:1883
[ === EVENT: RE-DEPLOY 2 - leading to re-connect === ]
1 Dec 08:47:05 - [trace] utils.writeFile - copied /data/flows.json TO /data/.flows.json.backup
1 Dec 08:47:05 - [trace] utils.writeFile - written content to /data/flows.json.$$$
1 Dec 08:47:05 - [trace] utils.writeFile - renamed /data/flows.json.$$$ to /data/flows.json
1 Dec 08:47:05 - [debug] saved flow revision: 1cf16b3e9fa0bb14fde3cf71614001c7
1 Dec 08:47:05 - [info] Stopping modified flows
1 Dec 08:47:05 - [debug] red/nodes/flows.stop : stopping flow : 8fe02e49cbc1e1e3
1 Dec 08:47:05 - [trace] [flow:8fe02e49cbc1e1e3] stop flow
1 Dec 08:47:05 - [trace] Stopping node debug:e426ca5edb464827
1 Dec 08:47:05 - [trace] Stopping node mqtt in:98eda388285104a1
1 Dec 08:47:05 - [debug] red/nodes/flows.stop : stopping flow : global
1 Dec 08:47:05 - [trace] [flow:global] stop flow
1 Dec 08:47:05 - [trace] Stopped node debug:e426ca5edb464827 (0ms)
1 Dec 08:47:05 - [trace] Stopped node mqtt in:98eda388285104a1 (0ms)
1 Dec 08:47:05 - [info] Stopped modified flows
1 Dec 08:47:05 - [trace] runtime event: {"id":"runtime-state","payload":{"state":"stop","deploy":true},"retain":true}
1 Dec 08:47:05 - [info] Updated flows
1 Dec 08:47:05 - [info] Starting modified flows
1 Dec 08:47:05 - [debug] red/nodes/flows.start : not starting disabled flow : 404a5fc31d9bfebc
1 Dec 08:47:05 - [debug] red/nodes/flows.start : not starting disabled flow : 80c0daf0d6dc14e8
1 Dec 08:47:05 - [debug] red/nodes/flows.start : not starting disabled flow : fefe4cc15c24e3f0
1 Dec 08:47:05 - [trace] [flow:global] start flow [global]
1 Dec 08:47:05 - [trace] [flow:global] ------------------|--------------|-----------------
1 Dec 08:47:05 - [trace] [flow:global]  id               | type         | alias
1 Dec 08:47:05 - [trace] [flow:global]  ec6252675c95ed29 | server       |
1 Dec 08:47:05 - [trace] [flow:global]  09a1213024a9a03b | influxdb     |
1 Dec 08:47:05 - [trace] [flow:global]  d50d0c9f.31e858  | tls-config   |
1 Dec 08:47:05 - [trace] [flow:global]  5d7e54ca.019d44  | influxdb     |
1 Dec 08:47:05 - [trace] [flow:global]  5a4cacde8bbbdebd | mqtt-broker  |
1 Dec 08:47:05 - [trace] [flow:8fe02e49cbc1e1e3] start flow [8fe02e49cbc1e1e3]
1 Dec 08:47:05 - [trace] [flow:8fe02e49cbc1e1e3] ------------------|--------------|-----------------
1 Dec 08:47:05 - [trace] [flow:8fe02e49cbc1e1e3]  id               | type         | alias
1 Dec 08:47:05 - [trace] [flow:8fe02e49cbc1e1e3]  98eda388285104a1 | mqtt in      |
1 Dec 08:47:05 - [trace] [flow:8fe02e49cbc1e1e3]  e426ca5edb464827 | debug        |
1 Dec 08:47:05 - [trace] runtime event: {"id":"runtime-state","payload":{"state":"start","deploy":true},"retain":true}
1 Dec 08:47:05 - [info] Started modified flows
1 Dec 08:47:05 - [trace] runtime event: {"id":"runtime-deploy","payload":{"revision":"1cf16b3e9fa0bb14fde3cf71614001c7"},"retain":true}
1 Dec 08:47:05 - [info] [mqtt-broker:main] Connected to broker: mqtt://192.168.0.24:1883
[ === EVENT: RE-DEPLOY 3 - leading to disconnect === ]
1 Dec 08:47:15 - [trace] utils.writeFile - copied /data/flows.json TO /data/.flows.json.backup
1 Dec 08:47:15 - [trace] utils.writeFile - written content to /data/flows.json.$$$
1 Dec 08:47:15 - [trace] utils.writeFile - renamed /data/flows.json.$$$ to /data/flows.json
1 Dec 08:47:15 - [debug] saved flow revision: aec89413f9c5c5862827576f6d44d909
1 Dec 08:47:15 - [info] Stopping modified flows
1 Dec 08:47:15 - [debug] red/nodes/flows.stop : stopping flow : 8fe02e49cbc1e1e3
1 Dec 08:47:15 - [trace] [flow:8fe02e49cbc1e1e3] stop flow
1 Dec 08:47:15 - [trace] Stopping node debug:e426ca5edb464827
1 Dec 08:47:15 - [trace] Stopping node mqtt in:98eda388285104a1
1 Dec 08:47:15 - [debug] red/nodes/flows.stop : stopping flow : global
1 Dec 08:47:15 - [trace] [flow:global] stop flow
1 Dec 08:47:15 - [trace] Stopped node debug:e426ca5edb464827 (1ms)
1 Dec 08:47:15 - [trace] Stopped node mqtt in:98eda388285104a1 (1ms)
1 Dec 08:47:15 - [info] Stopped modified flows
1 Dec 08:47:15 - [trace] runtime event: {"id":"runtime-state","payload":{"state":"stop","deploy":true},"retain":true}
1 Dec 08:47:15 - [info] Updated flows
1 Dec 08:47:15 - [info] Starting modified flows
1 Dec 08:47:15 - [debug] red/nodes/flows.start : not starting disabled flow : 404a5fc31d9bfebc
1 Dec 08:47:15 - [debug] red/nodes/flows.start : not starting disabled flow : 80c0daf0d6dc14e8
1 Dec 08:47:15 - [debug] red/nodes/flows.start : not starting disabled flow : fefe4cc15c24e3f0
1 Dec 08:47:15 - [trace] [flow:global] start flow [global]
1 Dec 08:47:15 - [trace] [flow:global] ------------------|--------------|-----------------
1 Dec 08:47:15 - [trace] [flow:global]  id               | type         | alias
1 Dec 08:47:15 - [trace] [flow:global]  ec6252675c95ed29 | server       |
1 Dec 08:47:15 - [trace] [flow:global]  09a1213024a9a03b | influxdb     |
1 Dec 08:47:15 - [trace] [flow:global]  d50d0c9f.31e858  | tls-config   |
1 Dec 08:47:15 - [trace] [flow:global]  5d7e54ca.019d44  | influxdb     |
1 Dec 08:47:15 - [trace] [flow:global]  5a4cacde8bbbdebd | mqtt-broker  |
1 Dec 08:47:15 - [trace] [flow:8fe02e49cbc1e1e3] start flow [8fe02e49cbc1e1e3]
1 Dec 08:47:15 - [trace] [flow:8fe02e49cbc1e1e3] ------------------|--------------|-----------------
1 Dec 08:47:15 - [trace] [flow:8fe02e49cbc1e1e3]  id               | type         | alias
1 Dec 08:47:15 - [trace] [flow:8fe02e49cbc1e1e3]  98eda388285104a1 | mqtt in      |
1 Dec 08:47:15 - [trace] [flow:8fe02e49cbc1e1e3]  e426ca5edb464827 | debug        |
1 Dec 08:47:15 - [trace] runtime event: {"id":"runtime-state","payload":{"state":"start","deploy":true},"retain":true}
1 Dec 08:47:15 - [info] Started modified flows
1 Dec 08:47:15 - [trace] runtime event: {"id":"runtime-deploy","payload":{"revision":"aec89413f9c5c5862827576f6d44d909"},"retain":true}
1 Dec 08:47:15 - [info] [mqtt-broker:main] Disconnected from broker: mqtt://192.168.0.24:1883
[ === EVENT: RE-DEPLOY 4 - leading to re-connect === ]
1 Dec 08:47:25 - [trace] utils.writeFile - copied /data/flows.json TO /data/.flows.json.backup
1 Dec 08:47:25 - [trace] utils.writeFile - written content to /data/flows.json.$$$
1 Dec 08:47:25 - [trace] utils.writeFile - renamed /data/flows.json.$$$ to /data/flows.json
1 Dec 08:47:25 - [debug] saved flow revision: 1cf16b3e9fa0bb14fde3cf71614001c7
1 Dec 08:47:25 - [info] Stopping modified flows
1 Dec 08:47:25 - [debug] red/nodes/flows.stop : stopping flow : 8fe02e49cbc1e1e3
1 Dec 08:47:25 - [trace] [flow:8fe02e49cbc1e1e3] stop flow
1 Dec 08:47:25 - [trace] Stopping node debug:e426ca5edb464827
1 Dec 08:47:25 - [trace] Stopping node mqtt in:98eda388285104a1
1 Dec 08:47:25 - [debug] red/nodes/flows.stop : stopping flow : global
1 Dec 08:47:25 - [trace] [flow:global] stop flow
1 Dec 08:47:25 - [trace] Stopped node debug:e426ca5edb464827 (0ms)
1 Dec 08:47:25 - [trace] Stopped node mqtt in:98eda388285104a1 (0ms)
1 Dec 08:47:25 - [info] Stopped modified flows
1 Dec 08:47:25 - [trace] runtime event: {"id":"runtime-state","payload":{"state":"stop","deploy":true},"retain":true}
1 Dec 08:47:25 - [info] Updated flows
1 Dec 08:47:25 - [info] Starting modified flows
1 Dec 08:47:25 - [debug] red/nodes/flows.start : not starting disabled flow : 404a5fc31d9bfebc
1 Dec 08:47:25 - [debug] red/nodes/flows.start : not starting disabled flow : 80c0daf0d6dc14e8
1 Dec 08:47:25 - [debug] red/nodes/flows.start : not starting disabled flow : fefe4cc15c24e3f0
1 Dec 08:47:25 - [trace] [flow:global] start flow [global]
1 Dec 08:47:25 - [trace] [flow:global] ------------------|--------------|-----------------
1 Dec 08:47:25 - [trace] [flow:global]  id               | type         | alias
1 Dec 08:47:25 - [trace] [flow:global]  ec6252675c95ed29 | server       |
1 Dec 08:47:25 - [trace] [flow:global]  09a1213024a9a03b | influxdb     |
1 Dec 08:47:25 - [trace] [flow:global]  d50d0c9f.31e858  | tls-config   |
1 Dec 08:47:25 - [trace] [flow:global]  5d7e54ca.019d44  | influxdb     |
1 Dec 08:47:25 - [trace] [flow:global]  5a4cacde8bbbdebd | mqtt-broker  |
1 Dec 08:47:25 - [trace] [flow:8fe02e49cbc1e1e3] start flow [8fe02e49cbc1e1e3]
1 Dec 08:47:25 - [trace] [flow:8fe02e49cbc1e1e3] ------------------|--------------|-----------------
1 Dec 08:47:25 - [trace] [flow:8fe02e49cbc1e1e3]  id               | type         | alias
1 Dec 08:47:25 - [trace] [flow:8fe02e49cbc1e1e3]  98eda388285104a1 | mqtt in      |
1 Dec 08:47:25 - [trace] [flow:8fe02e49cbc1e1e3]  e426ca5edb464827 | debug        |
1 Dec 08:47:25 - [trace] runtime event: {"id":"runtime-state","payload":{"state":"start","deploy":true},"retain":true}
1 Dec 08:47:25 - [info] Started modified flows
1 Dec 08:47:25 - [trace] runtime event: {"id":"runtime-deploy","payload":{"revision":"1cf16b3e9fa0bb14fde3cf71614001c7"},"retain":true}
1 Dec 08:47:25 - [info] [mqtt-broker:main] Connected to broker: mqtt://192.168.0.24:1883
Mosquitto Logs:
08:46:53 | 1669884413: Received PUBLISH from mqttjs_a23a0c39 (d0, q0, r0, m0, 'zigbee2mqtt/bridge/logging', ... (212 bytes))
08:46:53 | 1669884413: Sending PUBLISH to mqttjs_a23a0c39 (d0, q0, r0, m0, 'zigbee2mqtt/bridge/logging', ... (212 bytes))
08:46:53 | 1669884413: Sending PUBLISH to nodered_bdc64086c6f62d72 (d0, q0, r0, m0, 'zigbee2mqtt/bridge/logging', ... (212 bytes))
08:46:53 | 1669884413: Received PUBLISH from mqttjs_a23a0c39 (d0, q0, r0, m0, 'zigbee2mqtt/Bedroom Window', ... (111 bytes))
08:46:53 | 1669884413: Sending PUBLISH to 7cIL6MUkpu61IzJvwMcuDH (d0, q0, r0, m0, 'zigbee2mqtt/Bedroom Window', ... (111 bytes))
08:46:53 | 1669884413: Sending PUBLISH to mqttjs_a23a0c39 (d0, q0, r0, m0, 'zigbee2mqtt/Bedroom Window', ... (111 bytes))
08:46:53 | 1669884413: Sending PUBLISH to nodered_bdc64086c6f62d72 (d0, q0, r0, m0, 'zigbee2mqtt/Bedroom Window', ... (111 bytes))
08:46:56 | 1669884416: Received UNSUBSCRIBE from nodered_bdc64086c6f62d72
08:46:56 | 1669884416:         zigbee2mqtt/#
08:46:56 | 1669884416: nodered_bdc64086c6f62d72 zigbee2mqtt/#
08:46:56 | 1669884416: Sending UNSUBACK to nodered_bdc64086c6f62d72
08:46:56 | 1669884416: Received DISCONNECT from nodered_bdc64086c6f62d72
08:46:56 | 1669884416: Client nodered_bdc64086c6f62d72 disconnected.
08:46:59 | 1669884419: Received PUBLISH from 7cIL6MUkpu61IzJvwMcuDH (d0, q1, r1, m51668, 'hass-states/sensor/router_packets_received/state', ... (9 bytes))
08:46:59 | 1669884419: Sending PUBACK to 7cIL6MUkpu61IzJvwMcuDH (m51668, rc0)
08:46:59 | 1669884419: Received PUBLISH from 7cIL6MUkpu61IzJvwMcuDH (d0, q1, r1, m51669, 'hass-states/sensor/router_packets_sent/state', ... (8 bytes))
08:46:59 | 1669884419: Sending PUBACK to 7cIL6MUkpu61IzJvwMcuDH (m51669, rc0)
[ === ... snipping unrelated home assistant events like the ones above and below ... === ]
08:47:02 | 1669884422: Received PUBLISH from 7cIL6MUkpu61IzJvwMcuDH (d0, q1, r1, m51784, 'hass-states/binary_sensor/ping_outside/device_class', ... (14 bytes))
08:47:02 | 1669884422: Sending PUBACK to 7cIL6MUkpu61IzJvwMcuDH (m51784, rc0)
08:47:02 | 1669884422: Received PUBLISH from 7cIL6MUkpu61IzJvwMcuDH (d0, q1, r1, m51785, 'hass-states/binary_sensor/ping_outside/friendly_name', ... (18 bytes))
08:47:02 | 1669884422: Sending PUBACK to 7cIL6MUkpu61IzJvwMcuDH (m51785, rc0)
08:47:05 | 1669884425: New connection from 192.168.16.1:58698 on port 1883.
08:47:05 | 1669884425: New client connected from 192.168.16.1:58698 as nodered_bdc64086c6f62d72 (p5, c1, k60).
08:47:05 | 1669884425: No will message specified.
08:47:05 | 1669884425: Sending CONNACK to nodered_bdc64086c6f62d72 (0, 0)
08:47:05 | 1669884425: Received SUBSCRIBE from nodered_bdc64086c6f62d72
08:47:05 | 1669884425:         zigbee2mqtt/# (QoS 2)
08:47:05 | 1669884425: nodered_bdc64086c6f62d72 2 zigbee2mqtt/#
08:47:05 | 1669884425: Sending SUBACK to nodered_bdc64086c6f62d72
08:47:05 | 1669884425: Sending PUBLISH to nodered_bdc64086c6f62d72 (d0, q0, r1, m0, 'zigbee2mqtt/bridge/state', ... (18 bytes))
08:47:05 | 1669884425: Sending PUBLISH to nodered_bdc64086c6f62d72 (d0, q0, r1, m0, 'zigbee2mqtt/bridge/info', ... (21051 bytes))
08:47:05 | 1669884425: Sending PUBLISH to nodered_bdc64086c6f62d72 (d0, q0, r1, m0, 'zigbee2mqtt/bridge/devices', ... (38987 bytes))
08:47:05 | 1669884425: Sending PUBLISH to nodered_bdc64086c6f62d72 (d0, q0, r1, m0, 'zigbee2mqtt/bridge/groups', ... (2 bytes))
08:47:05 | 1669884425: Sending PUBLISH to nodered_bdc64086c6f62d72 (d0, q0, r1, m0, 'zigbee2mqtt/bridge/extensions', ... (2 bytes))
08:47:06 | 1669884426: Received PUBLISH from 7cIL6MUkpu61IzJvwMcuDH (d0, q1, r1, m51786, 'hass-states/sensor/mt1_wired_clients/state', ... (1 bytes))
08:47:06 | 1669884426: Sending PUBACK to 7cIL6MUkpu61IzJvwMcuDH (m51786, rc0)
08:47:06 | 1669884426: Received PUBLISH from 7cIL6MUkpu61IzJvwMcuDH (d0, q1, r1, m51787, 'hass-states/sensor/mt1_wired_clients/last_updated', ... (32 bytes))
08:47:06 | 1669884426: Sending PUBACK to 7cIL6MUkpu61IzJvwMcuDH (m51787, rc0)
08:47:12 | 1669884432: Received PUBLISH from 7cIL6MUkpu61IzJvwMcuDH (d0, q1, r1, m51829, 'hass-states/binary_sensor/ping_outside/device_class', ... (14 bytes))
08:47:12 | 1669884432: Sending PUBACK to 7cIL6MUkpu61IzJvwMcuDH (m51829, rc0)
08:47:12 | 1669884432: Received PUBLISH from 7cIL6MUkpu61IzJvwMcuDH (d0, q1, r1, m51830, 'hass-states/binary_sensor/ping_outside/friendly_name', ... (18 bytes))
08:47:12 | 1669884432: Sending PUBACK to 7cIL6MUkpu61IzJvwMcuDH (m51830, rc0)
08:47:15 | 1669884435: Received UNSUBSCRIBE from nodered_bdc64086c6f62d72
08:47:15 | 1669884435:         zigbee2mqtt/#
08:47:15 | 1669884435: nodered_bdc64086c6f62d72 zigbee2mqtt/#
08:47:15 | 1669884435: Sending UNSUBACK to nodered_bdc64086c6f62d72
08:47:15 | 1669884435: Received DISCONNECT from nodered_bdc64086c6f62d72
08:47:15 | 1669884435: Client nodered_bdc64086c6f62d72 disconnected.
08:47:22 | 1669884442: Received PUBLISH from 7cIL6MUkpu61IzJvwMcuDH (d0, q1, r1, m51831, 'hass-states/binary_sensor/ping_mt2/state', ... (2 bytes))
08:47:22 | 1669884442: Sending PUBACK to 7cIL6MUkpu61IzJvwMcuDH (m51831, rc0)
08:47:22 | 1669884442: Received PUBLISH from 7cIL6MUkpu61IzJvwMcuDH (d0, q1, r1, m51832, 'hass-states/binary_sensor/ping_mt2/last_updated', ... (32 bytes))
08:47:22 | 1669884442: Sending PUBACK to 7cIL6MUkpu61IzJvwMcuDH (m51832, rc0)
08:47:22 | 1669884442: Received PUBLISH from 7cIL6MUkpu61IzJvwMcuDH (d0, q1, r1, m51868, 'hass-states/binary_sensor/ping_outside/device_class', ... (14 bytes))
08:47:22 | 1669884442: Sending PUBACK to 7cIL6MUkpu61IzJvwMcuDH (m51868, rc0)
08:47:22 | 1669884442: Received PUBLISH from 7cIL6MUkpu61IzJvwMcuDH (d0, q1, r1, m51869, 'hass-states/binary_sensor/ping_outside/friendly_name', ... (18 bytes))
08:47:22 | 1669884442: Sending PUBACK to 7cIL6MUkpu61IzJvwMcuDH (m51869, rc0)
08:47:25 | 1669884445: New connection from 192.168.16.1:58044 on port 1883.
08:47:25 | 1669884445: New client connected from 192.168.16.1:58044 as nodered_bdc64086c6f62d72 (p5, c1, k60).
08:47:25 | 1669884445: No will message specified.
08:47:25 | 1669884445: Sending CONNACK to nodered_bdc64086c6f62d72 (0, 0)
08:47:25 | 1669884445: Received SUBSCRIBE from nodered_bdc64086c6f62d72
08:47:25 | 1669884445:         zigbee2mqtt/# (QoS 2)
08:47:25 | 1669884445: nodered_bdc64086c6f62d72 2 zigbee2mqtt/#
08:47:25 | 1669884445: Sending SUBACK to nodered_bdc64086c6f62d72
08:47:25 | 1669884445: Sending PUBLISH to nodered_bdc64086c6f62d72 (d0, q0, r1, m0, 'zigbee2mqtt/bridge/state', ... (18 bytes))
08:47:25 | 1669884445: Sending PUBLISH to nodered_bdc64086c6f62d72 (d0, q0, r1, m0, 'zigbee2mqtt/bridge/info', ... (21051 bytes))
08:47:25 | 1669884445: Sending PUBLISH to nodered_bdc64086c6f62d72 (d0, q0, r1, m0, 'zigbee2mqtt/bridge/devices', ... (38987 bytes))
08:47:25 | 1669884445: Sending PUBLISH to nodered_bdc64086c6f62d72 (d0, q0, r1, m0, 'zigbee2mqtt/bridge/groups', ... (2 bytes))
08:47:25 | 1669884445: Sending PUBLISH to nodered_bdc64086c6f62d72 (d0, q0, r1, m0, 'zigbee2mqtt/bridge/extensions', ... (2 bytes))
08:47:25 hostname zigbee2mqtt.sh[984327]: zigbee2mqtt    | Zigbee2MQTT:info  2022-12-01 09:47:25: MQTT publish: topic 'zigbee2mqtt/Office Window', payload '{"battery":100,"contact":true,"device_temperature":23,"linkquality":65,"power_outage_count":8,"voltage":3205}'
08:47:25 | 1669884445: Received PUBLISH from mqttjs_a23a0c39 (d0, q0, r0, m0, 'zigbee2mqtt/bridge/logging', ... (209 bytes))
08:47:25 | 1669884445: Sending PUBLISH to mqttjs_a23a0c39 (d0, q0, r0, m0, 'zigbee2mqtt/bridge/logging', ... (209 bytes))
08:47:25 | 1669884445: Sending PUBLISH to nodered_bdc64086c6f62d72 (d0, q0, r0, m0, 'zigbee2mqtt/bridge/logging', ... (209 bytes))
08:47:25 | 1669884445: Received PUBLISH from mqttjs_a23a0c39 (d0, q0, r0, m0, 'zigbee2mqtt/Office Window', ... (109 bytes))
08:47:25 | 1669884445: Sending PUBLISH to 7cIL6MUkpu61IzJvwMcuDH (d0, q0, r0, m0, 'zigbee2mqtt/Office Window', ... (109 bytes))
08:47:25 | 1669884445: Sending PUBLISH to mqttjs_a23a0c39 (d0, q0, r0, m0, 'zigbee2mqtt/Office Window', ... (109 bytes))
08:47:25 | 1669884445: Sending PUBLISH to nodered_bdc64086c6f62d72 (d0, q0, r0, m0, 'zigbee2mqtt/Office Window', ... (109 bytes))
08:47:25 | 1669884445: Received PUBLISH from 7cIL6MUkpu61IzJvwMcuDH (d0, q1, r1, m51870, 'hass-states/sensor/office_window_device_temperature/state', ... (2 bytes))
08:47:25 | 1669884445: Sending PUBACK to 7cIL6MUkpu61IzJvwMcuDH (m51870, rc0)
08:47:25 | 1669884445: Received PUBLISH from 7cIL6MUkpu61IzJvwMcuDH (d0, q1, r1, m51871, 'hass-states/sensor/office_window_device_temperature/last_updated', ... (32 bytes))
08:47:25 | 1669884445: Sending PUBACK to 7cIL6MUkpu61IzJvwMcuDH (m51871, rc0)
[ === ... snipping unrelated home assistant events like the ones above ... === ]
From the logs, it looks like the MQTT-In node is willingly disconnecting from the broker. I especially noted the Received UNSUBSCRIBE events in the Mosquitto logs when Node-RED disconnected.
Am I right in assuming that this is not intended behavior? Is there anything else I can do to diagnose the issue further?
This is a bit annoying to me because with every second re-deployment the MQTT node is disabled.
Thanks for any help!
Best,
Michael
Hi, without getting too deep into the details and logs, I think this is related to this issue: MQTT not reconnecting on edit if only only one mqtt node using the config node · Issue #3927 · node-red/node-red · GitHub which started here: MQTT not reconnecting if only only one mqtt node using it
And here is a PR that fixes it: fix single subscription mqtt node status by Steve-Mcl · Pull Request #3928 · node-red/node-red · GitHub
Please let me know if adding a 2nd subscription to some other topic fixes this
Hi, thanks for the pointer! I did some searching but didn't find this thread specifically, sorry about that.
Just adding a second node to the same flow didn't help (neither did a close or will message, by the way), but adding another node to a second flow (which is then unaffected by the re-deploy) did.
Just as a side node, I'm not sure why adding another node in the same flow should resolve this issue. From what I understood, the problem is too quick close/reregister, which also happens when I have two or three nodes in the same flow. The only way to reliable avoid the issue is to have another node in a different flow, which makes sure it's not closed.
Anyway, thanks again and thanks for that PR :slight_smile: Hope it'll go through soon so others aren't affected.
Cheers!
What deploy type do you do?
Full, modified flows or modified nodes?
The issue is related to internal state & how deploying flow/node changes occur.
When a single subscription exists and you re-deploy that node, it first gets destroyed (meaning there are no longer any subscriptions & thus it disconnects) - the fix in the PR handles this situation a bit more elegantly.
Ah, I forgot to mention: I'm doing modified flows.
Now it makes sense. If I just add another MQTT node to the same flow, the issue persists because I effectively still reload both nodes. When using "modified nodes", the issue is actually resolved by adding another node (because that node is not destroyed).
Thanks so much :slight_smile:
