nodered.service - Node-RED is a tool for wiring together hardware devices, APIs and online services in new and interesting ways.
Loaded: loaded (/etc/systemd/system/nodered.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2019-10-17 22:43:12 CEST; 1min 24s ago
Docs: http://nodered.org/
Main PID: 5468 (node-red)
Tasks: 11 (limit: 4915)
CGroup: /system.slice/nodered.service
└─5468 node-red
Oct 17 22:43:14 husova.maxbox.cz Node-RED[5468]: If the system-generated key is lost for any reason, your credentials
Oct 17 22:43:14 husova.maxbox.cz Node-RED[5468]: file will not be recoverable, you will have to delete it and re-enter
Oct 17 22:43:14 husova.maxbox.cz Node-RED[5468]: your credentials.
Oct 17 22:43:14 husova.maxbox.cz Node-RED[5468]: You should set your own key using the 'credentialSecret' option in
Oct 17 22:43:14 husova.maxbox.cz Node-RED[5468]: your settings file. Node-RED will then re-encrypt your credentials
Oct 17 22:43:14 husova.maxbox.cz Node-RED[5468]: file using your chosen key the next time you deploy a change.
Oct 17 22:43:14 husova.maxbox.cz Node-RED[5468]: ---------------------------------------------------------------------
Oct 17 22:43:14 husova.maxbox.cz Node-RED[5468]: 17 Oct 22:43:14 - [info] Starting flows
Oct 17 22:43:15 husova.maxbox.cz Node-RED[5468]: 17 Oct 22:43:15 - [info] Started flows
Oct 17 22:43:15 husova.maxbox.cz Node-RED[5468]: 17 Oct 22:43:15 - [info] [mqtt-broker:11b65d93.b32232] Connected to broker: mqtt://maxbox.maxbox.cz:1883
Trying to add nodes pointing to the broker running on localhost
Oct 17 22:54:18 husova.maxbox.cz Node-RED[5468]: 17 Oct 22:54:18 - [info] [mqtt-broker:1044c0d8.71d067] Connected to broker: mqtt://127.0.0.1:1883
Oct 17 22:54:18 husova.maxbox.cz Node-RED[5468]: 17 Oct 22:54:18 - [info] [mqtt-broker:6c280899.73bfb8] Connected to broker: mqtt://172.19.100.1:1883
Oct 17 22:54:18 husova.maxbox.cz Node-RED[5468]: 17 Oct 22:54:18 - [info] [mqtt-broker:f2b7941d.92b59] Connected to broker: mqtt://localhost:1883
That isn't exactly what I asked, you have restarted it as a service rather than running it in a terminal, but no matter, as you can see it has connected to the mqtt brokers correctly.
You say they are not showing connected in the browser however. Are other nodes showing status ok?
The node status updates and the Debug sidebar messages all reach the editor via a WebSocket connection between the editor and runtime. If something is disrupting that connection then it would cause both to be blank.
But if it was simply a broken websocket connection then the editor would show a notification that it had lost its connection to the runtime.
Are you running Node-RED behind any kind of proxy?
BTW, editor on my PC was (is) showing me messages "connection lsot... reconnecting" (i dont remember exact text of message) often.
I was just thinking the connection quality (speed) is poor.
