Mqtt send block not sending data to the things network
We are trying to send data to the thing network using mqtt. It connects to the things network but does not send the data. We have tried using multiple topics but it still would not work. The topic we are using now is brandweerlora/devices/microcontroller/down. In the pictures below you can see our configuration and the data we are trying to send.
Thanks in advance!
unknown1
unknown
your hostname was eu.thethings.network and port 1883, right ?
can you share here code of this flow ?
yes it is indeed eu.thethings.network with port 1883.
[Moderator note: I've edited this post to make the flow importable]
[{"id":"63a9948e.a5fe1c","type":"tab","label":"Flow 2","disabled":false,"info":""},{"id":"8fb86f3e.10f92","type":"inject","z":"63a9948e.a5fe1c","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[48,120,48,51]","payloadType":"bin","x":270,"y":200,"wires":[["122fb165.01424f","316ce673.97fb8a"]]},{"id":"122fb165.01424f","type":"mqtt out","z":"63a9948e.a5fe1c","name":"","topic":"brandweerlora/devices/microcontroller/down","qos":"0","retain":"false","broker":"f69f7f15.917c8","x":590,"y":420,"wires":[  ]},{"id":"316ce673.97fb8a","type":"debug","z":"63a9948e.a5fe1c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":570,"y":240,"wires":[  ]},{"id":"f69f7f15.917c8","type":"mqtt-broker","name":"","broker":"eu.thethings.network","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
download flow and share.
I am a new user i cant upload attachments
Check on this video how need convert data and send to mqtt
now you data was send like raw and you have resul on topic 0x03
If you want send data like object need convert to str or json after send to mqtt
Did you try TLS (secure connection) with port 8883?
