Msg ui property Y axis scale
It is possible to decide the scale of Y-axis in a chart, e.g. line chart?
Maybe sending some msg.ui_property messages?
yes as described in the docs
sorry...what docs...I didnt find them on web
find the node on flows.nodered.org then follow the config-fields.md link in the text
In the config for the chart there are Y Max and Y Min fields.
Not min and max...the scale
you need to describe what you mean. As to me if you define the min max you define the scale.
I have this y-axis
Cattura
I want a step of 1, I dont want 2.5, 3.75, 1.25....
currently that isn't possible. You can set min and max - but it then auto generates the "ticks". There is possibly an option to set it to be integers only - but that would then not work if the scale was (for example) 0 to 1. You may be able to change the max suitably to make the ticks fit more how you want.
thak you for the exhaustive response
I know this is a resurrection of a year old thread, but has this been solved? I see that Node-Red is using the directives from this library (Angularjs-nvd3-directives) and that library offers the ability to change the Y Axis Tick style with the property yAxisTickFormat.
My chart data has values like x.xx and the Y axis label reflects that, but I'd like to format the label to x.x without actually changing my inout data.
