MSSQL node imports "xxx... & ... " to "xxx... & ..."
Hi, MSQL node converts the "&" into "&" in a text field.
Here is the code in the MSSQL node:
INSERT INTO [mrs_Work]
(PrjNo, ProjectName)
VALUES (
'{{{payload.PrjNo}}}',
'{{{payload.ProjectName}}}'
The inbound field msg.payload.ProjectName contains - for instance" Integrated Plan & Schedule - which then is stored in MSSQL as Integrated Plan & Schedule
How can I stop this conversion?
If you are using node-red-contrib-mssql-plus you can setup parameters in the UI & use them in the query...
VALUES (
  @PrjNo,
  @ProjectName
Better still, create a stored procedure & pass in parameters.
See the 1st screenshot in the readme
Thank you! I will try it and report back. But I am using node node-red-contrib-mssql-plus.
@Steve-Mcl - found my problem - mybad, I had a text string inserted with '{{x}}', instead of '{{x}}}' in the node.
I am doing bulk'ish upload, 9300 records, did not know there were a beta solution - I came over the problem by batching in batches of 1000 - once you come ou of beta - I will use that rather. the 10,000 records are growing ...
Bulk insert is out of beta. Are you running v0.7.1?
Also, are the updates/inserts coming from free text? Using mustache is vulnerable to SQL injection hacks, you would be better off taking my advice about using parameters or stored procedure.
Just upgraded to 0.7.1 - okay - did not know - let me refactor to use Bulk - right now I package an array of 1000 objects, then through them at a Spit note - feed them into the MSSQL node - one at a time, 2 seconds later the next 1000, and so on, but still getting niggling errors.
Let me see how to do that - and get rid of mustaches....
I download from our ERP into a spreadsheet, then use the Excel node to package it into a json Array, then point that to the 1000' breaker upper....
Yuk. What a kerfuffle.
Doesn't the ERP have a callable endpoint to avoid the whole excel part?
Yes, it has, but IT does not want to let me in .... 8-( Still busy convincing them. IN the mean time - I must run a business.,.....
I never understand that. If there is a http endpoint that has been coded correctly there is nothing your application can do to break the ERP.
Bloody IT. :wink:
Funny, examples not showing....
No Examples
Where is it running? Have you refreshed browser after update?
Okay to download in a spreadsheet.... but not an end-point - as then I have access to the data. Wait until they find out I am pushing it into SQL .... from the spreadsheet.......
Closed browser now, re-opened, still not working. Safari in Mac. MS SQL on a NAS on Ubuntu - in Docker container.... Sweat solution .....
Most odd.
You can get examples here
Now not sure how I will use BULK. Can I point a 10,000 msg.payload formatted in JSON, array with 10,000 objects at it too? Do not want to download a spreadsheet from ERP, then by hand convert that into CSV, with all the problems with commas in fields, and then point a CSV to the MSSQL node. But let me look into your examples to see if such solutions exists.
If formatted correctly yes.
Have a look at example.
FLIPPEN HELL !!!! Ran the Bulk demo now, IT IS BLAZINGLY FAST !!!
Okay - got your BULK thing working, deleted reams and reams of work-around flows I had to build. Thank you Steve.
