Multiple changes of the button label
Hi everybody,
The project that I am working on is fairly simple. Looking for an idea about how best to do it.
I am creating an electronic checklist for my plane. 5-inch touch screen that will display what I need to do manually before the fly (some of this is critical, so manual switches are still there). I created a large button on the screen, that is showing "Fuel On", also audio announcement "Fuel On", after pressing the button, the label should change to "Master Switch ON" with the audio announcement "Master Switch ON", after that "Engine ON" etc, etc.
What would be the best way to implement this?
Should I do a button change, only label change? If so, how?
Thanks for your help
Robert
It's quite easy to implement but do you have feedback from the system so you can switch the button state according to incoming events or should it just be sequence of states the button will have?
No need to have a feedback, I simply have to switch "Fuel On" manually, press the button, and go to the next item. The only feedback is me pressing the button. The list is for me not to forget anything. With audio announcement I do not even have to look at the screen.
Normally, I have a piece of paper with the list of item I have to do before, let's say starting the engine. These are critical items, so still prefer to do it manually.
Then probably something like this may do the trick.
[{"id":"8c811146.a2541","type":"function","z":"a3ab0b27.873be8","name":"Set defaults","func":"let startSequence = [\n    {\n        id:0,\n        name:\"Fuel On\"\n    },\n    {\n      id:1,\n      name:\"Master Switch On\"\n    },\n    {\n      id:2,\n      name:\"Engine On\"  \n    }\n]\nglobal.set('startSequence',startSequence)\n\nvar state = startSequence.find(element => element.id == 0);\nglobal.set('currentState',state)\nreturn msg\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":210,"y":200,"wires":[["8488189a.5f6998"]]},{"id":"1d7b5e29.c55722","type":"inject","z":"a3ab0b27.873be8","name":"Init / reset","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":200,"y":140,"wires":[["8c811146.a2541"]]},{"id":"a4fb2aec.c39b68","type":"ui_button","z":"a3ab0b27.873be8","name":"","group":"f7080b8f.ec7f98","order":1,"width":0,"height":0,"passthru":false,"label":"{{payload}}","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":430,"y":300,"wires":[["7007a429.63614c"]]},{"id":"8488189a.5f6998","type":"function","z":"a3ab0b27.873be8","name":"Determine state for button label","func":"var state = global.get('currentState')\nvar sequence = global.get('startSequence')\nif(!state){\n    state = sequence.find(element => element.id == 0);\n    global.set('currentState',state)\n}\nmsg.payload = state.name\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":210,"y":300,"wires":[["a4fb2aec.c39b68","5b2bae94.7bb42"]]},{"id":"7007a429.63614c","type":"function","z":"a3ab0b27.873be8","name":"Change state","func":"var state = global.get('currentState')\nvar sequence = global.get('startSequence')\nif(state.id + 1 == sequence.length){\n    state = sequence.find(element => element.id == 0);\n}else{\n    state = sequence.find(element => element.id == state.id + 1);\n}\n\nglobal.set(\"currentState\",state)\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":590,"y":300,"wires":[["8488189a.5f6998"]]},{"id":"5b2bae94.7bb42","type":"ui_audio","z":"a3ab0b27.873be8","name":"","group":"f7080b8f.ec7f98","voice":"en-US","always":"","x":480,"y":200,"wires":[]},{"id":"f7080b8f.ec7f98","type":"ui_group","z":"","name":"default","tab":"cecac48e.2a6aa8","order":1,"disp":true,"width":"9","collapse":false},{"id":"cecac48e.2a6aa8","type":"ui_tab","z":"","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
Wow, thanks for doing it.
I am getting an error
" [error] [function:Change state] TypeError: Cannot read property 'id' of undefined"
You should press the init first
And you can set the inject node to do it automatically
Got it,
thanks
Appreciate, will try to digest it and learn how you did it.
Thanks again
Welcome to the forum. And don't hesitate to ask questions about the solution cos that's the way to learn things.
Fantastic, did not expect such a quick fix to the problem that I was facing.
Thanks again
Robert
Would love to see it in action.
