Multiple line graph using only MQTT Values
Hi here,
i m a newbe in Nodered so sorry if my question seems dummy.
I am trying to build a graph from only the values ​​coming from my MQTT Topic.
it must be a multiline graph.
from my MQTT, I get the timestamp supposed to be represented on my x-axis, and some values ​​x, y, z, r and ö which are the different lines of my graphs.
my concerns are therefore the following.
  • how to use timestamp from my topic
    -how to draw the different lines on the same graph and set their value to 0 in case I do not receive data at a certain time t
thanks
for now, here's a snippet of code that I'm trying to implement
msg.timestamp=msg.payload.test_ts; //use the time content in my topic
var x={};
var y={};
var z={};
var r={};
var o={};
//var x=0;
//var y=0;
//var z=0;
//var r=0;
//var o=0;
x.payload = msg.payload.test_ax;
x.topic="x";
y.payload = msg.payload.test_ay;
y.topic="y";
z.payload = msg.payload.test_az;
z.topic="z";
r.payload = msg.payload.test_rx;
r.topic="r";
o.payload = msg.payload.test_rz;
o.topic="o";
return(x,y,z,r,o);
also when i m checking the debugging file, i m getting only one value, don t know why
The chart node has valuable information in the information panel, which links here.
