Multiple line node comment
ONLY FOR DUMMIES LIKE ME : if you want write comment with more than one line, insert /n with spaces inside the text. Simple. e.g. OVERVIEW \n OUT 6 \n Actual power (KW)
Hey I've been using NR for nearly 5 years and didn't know that.
UPDATE : I do not know from which NR version this is possible to do, but e.g. in NR 1.0.3 is not possible to put more than a line into a comment with the same method.
