Iam new to Node-Red, Was creating a flow for multiple users so they can insert data to Mysql database.
i have used join node with 2 different topic. So upon 2 submits join node output will be generated and data will be dumped into database.
problem here is if 2 users using the same flow, if one user submits one topic and another user submit another topic , join node will generate output getting data of 2 users and wrong data is dumped into database.
So you have two distinct flows to achieve 1 db update? That would seem to be fraught with issues anyway. Is there no way you can combine that to a single flow? Then you wouldn't need the join and your multi-user inputs would work as expected (unless those users try to update the same record).
